Home > Technical (L322) > LPFP L322 td6 |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 |
Did you let the fuel run a bit low before filling up?. Below quarter tank, these ff's can suck up some crap out of the tank.
6th Jan 2017 7:47am |
littlecub Member Since: 02 Apr 2013 Location: Ulverstone,Tassie Posts: 324 |
Changed the filter and after a bit of coaxing it started. stopped, started, stopped,started and got it running.
6th Jan 2017 9:03am |
Update.
21st Jan 2017 12:14am |
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 |
Seems intank pump is faulty.
21st Jan 2017 9:17am |
Well I finally got my beast back.
27th Jan 2017 2:21am |
Was about to say I change my fuel filter every service as the cost of it is pretty small here, albeit I do 6k services FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
27th Jan 2017 7:25am |
Trewy1 Member Since: 11 Dec 2017 Location: Bedfordshire Posts: 2 |
I got a problem starting my td6 I can get it running with easy start it will run properly until I give it a good boot it will loose power and once I turned it off it will not start again can anyone point in the right direction |
11th Dec 2017 9:04am |
High pressure pump is dead I bet.
12th Dec 2017 9:21am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
When I had the doesn't want to start symptoms it was 2 knackered injectors once i'd limped home and had them all cleaned, tested and repaired as required the car never missed a beat! Yesterday I couldn't spell Engineer... Today I are one!
12th Dec 2017 11:05am |
