Home > Technical (L322) > Td6 injectors |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
The injectors do not need programming. The high-pressure pump at the front left of the engine should not make any discernable noise above the normal engine level 2007 TDV8 VSE
21st Dec 2017 2:54am |
Who swapped the injectors? Are you sure all the old washers came out, all new washers or at least old washers went back in after ensuring the locating holes were clean and free of carbon? Are all the clamps the right way round? 2007 TDV8 VSE
21st Dec 2017 5:08am |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 799 |
im with wayneg on this , if there was no noise before then there shouldn't be one now pal , id start looking incase you do some real damage by driving it |
21st Dec 2017 2:10pm |
Coconut Member Since: 12 Feb 2016 Location: Watford Posts: 36 |
Thanks for the update
21st Dec 2017 7:21pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Might be worth having him recheck his work sir... Get the timing checked as this too will make it pink/rattle |
21st Dec 2017 7:33pm |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 146 |
Even reputable mechanics can make mistakes sometimes....Have him check the work he's done. Agree with bembo; don't drive it this way.
22nd Dec 2017 8:09am |
Thank you all will have him re check things
22nd Dec 2017 3:32pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Are you sure it's not normal?
26th Dec 2017 2:33am |
Had a quick look myself the other day.
26th Dec 2017 3:02am |
