Home > Maintenance & Mods (L322) > 4.4 tdV8 Sucker |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3685 |
Father Xmas has given me a sucker.
26th Dec 2017 1:50pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34935 |
surely a colonoscopy would be better at a hospital!!
26th Dec 2017 1:53pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
26th Dec 2017 2:56pm |
Nino,
26th Dec 2017 3:14pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
Nice one BB - they are brilliant. Changing oil on any of the families cars is so simple now and as you say with the opie oil discount oil changes are cheap!. Ade. 405 AB exec seats Baltic and Cirrus
26th Dec 2017 6:58pm |
SinbadRose Member Since: 21 Aug 2017 Location: Merseyside Posts: 114 |
So stupid question time, I take it without the dipstick on the 2011 you will be going in through the oil filler? Take it you can still get all the way to the bottom with it? |
27th Dec 2017 12:07pm |
Sucking the old oil out is simple.
27th Dec 2017 12:26pm |
Excellent, thanks for the quick reply. I may look at one for the future, as I would like to change the oil every few months/5k ish myself. I am with you on the old and bad back part Looks like a really handy bit of kit. |
27th Dec 2017 12:44pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16176 |
Simbad... Pretty much the only way to change engine oil in a 2011 & newer FFRR is to suck it out... Its how JLR designed them all now a days |
27th Dec 2017 4:09pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Excellent machine , 115 stg , well worth it 2015 4.4 AB
27th Dec 2017 7:42pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Thought I'd remembered an old thread on draining vs sucking and found this:
. Thoughts? Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
28th Dec 2017 10:01am |
Greg,
28th Dec 2017 10:25am |
Greg, first time I changed oil in my car was like that, bit messy, then i realise that the same pipe i disconnected to drain oil is the pipe you hook up the sucker to extract oil, soo same thing - you get same amount of oil out either way. i do drain oil from the small pocket above crossmember (every 3d oil change).
28th Dec 2017 10:46am |
Sure - seems like there are benefits to sucking.
28th Dec 2017 11:26am |
