Home > Technical (L322) > Leak in Boot |
colinwebster Member Since: 19 Dec 2017 Location: Devon Posts: 43 |
HI All,
2nd Jan 2018 2:43pm |
Thanks Dragon, I have the factory removable towbar.....Ill gives it a check buy seems to be coming from above that level????
2nd Jan 2018 3:18pm |
aja500 Member Since: 15 Oct 2017 Location: South East Posts: 817 |
I also had exactly the same problem - It was caused by the rubber seal around the boot, which had perished over time.
2nd Jan 2018 8:42pm |
aja500; Thanks for your reply.
2nd Jan 2018 8:57pm |
After muchos rain last night, the diagnosis is the tailgate seal....
3rd Jan 2018 9:43am |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Try it, you've 2 chances!!
3rd Jan 2018 11:24am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Just been out to check mine expecting to find a pond in the wheel well but there isn't!
3rd Jan 2018 11:48am |
^^ But you've got to ask how old is your car and have you had it from new..... There is nothing to say that a previous owner hasn't sorted the wheel well well !! Yesterday I couldn't spell Engineer... Today I are one!
3rd Jan 2018 4:06pm |
Yep, somebody else has probably spent countless hours pulling their hair out trying to fix it before my ownership! |
3rd Jan 2018 5:03pm |
3rd Jan 2018 6:55pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
Look closely at the upper tailgate rubber seal at the top corner on the passenger side. The seal is poorly designed to fit round tight corners and tends to splay resulting in rainwater leaking into the body cavity it's mounted on and then appearing in the boot area including around the spare wheel. |
3rd Jan 2018 8:31pm |
Ok so I’ve sealed it up now and so far so good. If this fails I’ll get a new seal but at least I found the problem. |
3rd Jan 2018 9:08pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1898 |
Glad you sorted it, it can be such a pita to find these leeks ..... (see what I did their) 😂
4th Jan 2018 9:52pm |
Scottish Humour |
4th Jan 2018 10:01pm |
