Home > Technical (L322) > [solved] Where should this connect to?
Tooltime79
United Kingdom 2010 Range Rover Vogue SE TDV8 Santorini Black
I was just checking over the car this afternoon and noticed a small pipe was dangling under the air box. Looks like a vacuum pipe but I can’t work out where it should connect to. Anyone got any ideas? Circled red in the photo.
It is a 2010 3.6.
Thanks
Post #464542 14th Jan 2018 5:36pm
mpirie
Have a look in the Wiki section for the 2010 workshop manual.
It'll tell you where the hose connects to.
Mike
Post #464630 15th Jan 2018 11:18am
Tooltime79
Thanks Mike - I did have a look last night in the WM but couldn’t obviously see it identified (probably because I don’t know what it actually is for!)....will have another more careful look though.
Cheers
Tim
Post #464634 15th Jan 2018 11:26am
mpirie
Check out this link.
http://www.fullfatrr.com/forum/topic17623.html
It should take you to the Wiki link to download thw workshop manual.
Is it the 4.4 diesel you have?.
Mike
Post #464700 15th Jan 2018 8:38pm
Tooltime79
HI Mike,
I already have this downloaded - that was what I was looking through last night and couldn't find see the pipe referred to (hence the plea for help!). Going to have another look through it tonight though to see if I missed it though.
It is the 3.6 so that version of the WM does cover my engine.
Thanks
Tim
Post #464702 15th Jan 2018 8:51pm
might be worth finding a similar FF and comparing the engine layout Tim.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #464710 15th Jan 2018 10:04pm
Tooltime79
I think you might be right Stan. Doesn't seem to be bringing up any fault codes or impacting on performance so can't be that important!
Post #464713 15th Jan 2018 10:29pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Maybe rename your post need help from 3.6 owners, they are a lovely , helpful bunch ( i used to be one ) 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #464718 15th Jan 2018 11:12pm
Stevie_b
Scotland 2002 Range Rover Vogue Td6 Zermatt Silver
Hi, I'm sure it connects to a pipe on the air box Very Happy
Stevie.
Post #464723 15th Jan 2018 11:49pm
Tooltime79
Stevie - thank you! You are spot on...I have now found it in the workshop manual, something to do with a port deactivation pipe. The reason it isn’t connected is that the plastic bit it is meant to connect to on the air box seems to have snapped off which is why I couldn’t see it before. Now just need to find a way to reconnect it!
Thanks for everyone’s input.
Cheers
Tim
Post #464729 16th Jan 2018 1:45am
Stevie_b
No bother, good luck in the repair.
Stevie.
Post #464817 16th Jan 2018 10:23pm
