Home > Technical (L322) > Loose mirror |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3075 |
On the lower side of the mirror housing where the puddle lights are, there is a round plastic plug with a small slit for a screwdriver to prise open. Inside there are 2 screws - these may be loose. |
20th Jan 2018 5:37pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34959 |
theres also a 'how to' in the wiki re loose mirrors... ... - .- -.
20th Jan 2018 5:40pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
Thank you Dolphinboy, just had a look and sadly I don’t see any plastic plug Wish I had though as that sounds like an easy fix! Thanks anyway |
20th Jan 2018 5:53pm |
Thanks Stan, I looked at that earlier, shame the photos are missing. I was hoping I wouldn’t have to remove the door card and the mirror assembly for this...I’ll have another read |
20th Jan 2018 5:57pm |
Does anybody know if I can remove the mirror cover/cap and if I can, is there a facility to tighten the mirror wobble there? As already stated the mirror arm from the door is fine. Thanks in advance.
20th Jan 2018 11:34pm |
don't think you can ...you might be able to prise the mirror off a get 'in' that way..do a search for something like 'broken mirror' and see what comes up.. ... - .- -.
21st Jan 2018 9:18am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Stan's right. I found out because my mirror got whacked by a passing taxi a few weeks back. The mirror glass popped out, there it was just hanging on the cables. I pulled over and it popped straight back in.
21st Jan 2018 9:31am |
Thanks Stan & Greg, I found this on YouTube, hopefully there will be a tightening mechanism behind the cover, I’ll maybe have a go later today and report back.
21st Jan 2018 9:40am |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
this is what you'll find inside.
21st Jan 2018 10:13am |
Thank you very much for the photos nino_nino
21st Jan 2018 12:31pm |
this is the main metal casting that pivots, so i would assume this bolts must be what is holding outside plastic structure.
21st Jan 2018 2:00pm |
Many thanks once again nino_nino
21st Jan 2018 2:16pm |
Finally got round to trying to tighten up the wobbling o/s mirror. Mirror cap came off no problem, tightened the bolts nino_niro highlighted but made no difference
6th May 2018 5:33pm |
The complete mirror assembly is wobbling up and down as per the red arrow in this photo:
6th May 2018 5:38pm |
