Home > For Sale & Wanted > [wanted] HDC Switch |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
(Wanted)HDC switch or a good method of repair , button snapped off! |
23rd Jan 2018 10:12pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
moved to the correct section ... - .- -.
23rd Jan 2018 10:26pm |
Sorry for wrong section , thought it might be a techie help as well as wanted, however , Mitre mate....Halfords? I’m wandering if I could embed some very small pins into both bits as well as some sort of glue. Is Araldite the same as Mitre mate ? |
23rd Jan 2018 11:13pm |
Screwfix, araldite is not the same. Much more messy. Mitrefix is colourless and fast grab. But don’t be tempted to operate the switch for an hour or 2.
24th Jan 2018 8:25am |
Many thanks NMJ will look it up! |
24th Jan 2018 8:53am |
Didn't really work , the plastic is too hard to grip the button, so I drilled two small 1mm holes and dropped or gently pushed two small panel pins in to what was left of the surface leaving a small amount protruding so that the button can sit onto them . Unfortunately to secure the button which had a void inside to accommodate the pins and so filled these up with molecular metal. This part didn't work so well as the pins had too much movement and so the button is not too stable , perhaps I will try Araldite instead? |
8th Feb 2018 7:58pm |
