Home > In Car Electronics (L322) > Advice on sticking dashcam mount to windscreen
Rob99
I've now tried mounting my dashcam to the windscreen 3 times with the sticky pads supplied and each time it's fine for about a week and then just falls off Sad
Bit fed up with it now so am thinking maybe I can bond it to the screen with some kind of permanent adhesive as the cam detaches from the mount anyway for when I need to remove it.
Anyone else had similar problem? Thoughts on best thing to use?
Wondered about black adhesive silicon or maybe araldyte or similar.
Cheers
Rob 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #465799 24th Jan 2018 12:40am
clean surfaces and 3m tape or sticky pads (ebay)..
or you can use gorilla or mammoth tape from tool station/screwfix.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #465806 24th Jan 2018 8:16am
I did similar, ensure the glass is clean and I used no more nails tape Thumbs Up
Post #465816 24th Jan 2018 9:50am
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
3 Meters of tape!! That's an awful lot!!! Whistle
Post #465829 24th Jan 2018 11:06am
very good Paul Rolling Eyes
Laughing ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #465835 24th Jan 2018 11:52am
V8Noise
United Kingdom 2017 Range Rover Autobiography 5.0 SC V8 Carpathian Grey
Pop into your local Autoglass etc, and see what they would recommend.
I had an interior mirror on my Wrangler that came off and went into ask and the boys did it for me there and then with no charge. Whatever they did, it stayed on the screen afterwards. 2017 5.0 Autobiography Supercharged
2005 Merc SL350
2005 Disco HSE 2.7 oil burner
Post #465839 24th Jan 2018 12:29pm
Rob99
Thanks chaps, going to pop into screwfix on the weekend Thumbs Up 2017 4.4 SDV8 Autobiography
Post #465878 24th Jan 2018 5:54pm
Might also be an idea to heat the glass up to avoid any condensation issues in this cold weather. Got - 2017 SDV8 Autobiography in Loire Blue
Post #465944 25th Jan 2018 12:59am
Rob99
Well, 4 months in and the Censored ing thing has fallen off again........ Big Cry Big Cry
I really thought I had it sorted this time but evidently not. I could stick it again and accept it may only last a few months but looking at it a bit more today I think the problem is, not that the dashcam is too heavy for the adhesive, but that the fact there is a power cable connected to the GPS "foot" (which is what sticks to the windscreen) and another connected to the dashcam itself which comes from the rear cam and I think the combination of these 2 putting constant downward pressure on the dashcam is proving too much for the sticky bits.
I'm now looking at possibly fabricating a metal bracket so there is a larger surface area to stick to, or a bracket mechanically fixxed to something solid behind the rearview mirror. Just on that, does anyone know if its easy to remove the plastic cover behind the mirror, and whether there is then something I can attach a bracket too.
Thoughts...... 2017 4.4 SDV8 Autobiography
Post #481003 15th Jun 2018 6:58pm
GGDR
Rob is the cable pulling it too tightly away from the screen?
All adhesives get soft in this warmer weather, maybe the cable is tugging it a bit which when it's soft maybe enough to pull it off?
Mine popped off the other day but it's been stuck there for a year. Pressed it back and all good since.
+1 for the 3M pads/tape. Make sure it's genuine not 99p off ebay, (usually a good sign of a counterfeit).
. Cheers, Greg
Post #481005 15th Jun 2018 8:11pm
Rob99
The cables aren't really "pulling" at the dashcam and are mainly tucked into the headlining. I've tried genuine 3m pads, adhesives etc and they all work to varying degrees.
I now just want a permanent solution so I don't have to wonder every time I get in the car whether the dashcam has fallen off again.
Hence why I'm looking at a possible mechanically fixed option, maybe to some part of the rear view mirror assembly. Just need to work out how to get the plastic cover trim off without (a) breaking any fixing lugs or (b) cracking the windscreen Shocked 2017 4.4 SDV8 Autobiography
Post #481099 16th Jun 2018 9:52pm
does this pic help Rob...it shows how the sensor cover lifts from the screen..
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #481132 17th Jun 2018 8:52am
Boxbrownie
United Kingdom 2008 Range Rover Vogue SE TDV8 Java Black
Have you tried a small suction cup as supplied by many dash Cams? Ours is fitted in our i3 (not got around to the RRFF yet) and it’s been in there since last September without dropping off, just make sure the screen area is clean and slightly dampen the cup before fitting. David
Please let me know if my comments upset you, I may wish to upset you again.
Post #481145 17th Jun 2018 11:33am
Before fitting any device, suction cups or sticky pads I would suggest cleaning the screen area with methylated spirits.
Works for me, never had anything fall off. Thumbs Up
Post #481153 17th Jun 2018 12:26pm
ilard
I would use a moistened clay bar to remove all contaminants, polish dry, then stick. You might be surprised by the amount of filth that’s actually on an apparently clean piece of glass.
Post #481176 17th Jun 2018 4:24pm
