Home > General > A Fortnight in the airport carpark...
Gyre8
England 2006 Range Rover Vogue SE 4.4 V8 Tonga Green
Will the battery be flat when I get back?
Anyone else left their FFRR for a fortnight and it started up fine?
Post #466448 29th Jan 2018 11:40am
Sandyt
I have only used valet parking so guess they jump it as clock is never right but then they may disconnect battery not much help afraid - I carry a lithium jump starter when I go to france just in case might be worth looking at
Post #466449 29th Jan 2018 11:43am
Sandyt
https://www.amazon.co.uk/DBPOWER-18000mAh-...start+pack
This sort of thing Thumbs Up
Post #466450 29th Jan 2018 11:44am
Can it ? Yes - examples here
Will yours ? Who knows
Do you have any difficulty starting on cold mornings ? I have jump leads and a Floureon booster pack in my boot just in case (Similar to the one Sandy suggested) Thumbs Up
Post #466451 29th Jan 2018 11:47am
Gyre8
Battery newish (6 Months). Normally starts first time - so maybe I'll be OK. Think I will buy one of those battery jump-starter thingies just in case. It's a handy thing to have anyway.
Thanks both.
Post #466452 29th Jan 2018 11:52am
yours is a petrol so it should be ok..its the diesels that generally have problems.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #466453 29th Jan 2018 11:54am
Bill
Left my 5 year old diesel for 4 weeks... no problems. Filters are in fact so good that in certain circumstances, when the ambient air is already polluted, a diesel car will tend to extract more particles from the air than it emits. Emissions Analytics worked with........etc etc
He who dies with the most toys wins...
Post #466468 29th Jan 2018 2:11pm
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
I can't see it being a problem, providing you have no power drain.
I rarely use mine & it starts first time without hesitation, even in the cold. Battery is 2 years old & petrol.
Post #466471 29th Jan 2018 2:39pm
Clivefog
Not had any problem both times I've left my petrol one.
Worry about it if it happens when you get back.
Post #466475 29th Jan 2018 4:24pm
NVB
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
My TD6 with a new battery would go four days at most when it had a 240mA parasitic drain. Now I have the drain down to 100mA and it's been fine up to 7 days (haven't tried it any longer) but I suspect 14 days would be pushing it. If you have the standard 50mA drain that these cars are supposed to have when asleep, and you have a decent battery, I think you will be fine. RR History
1988 2.4td Classic 1999 to 2020
1992 3.9efi Westminster Classic 2004-2005
2005MY L322 3.0TD6 Vogue 2016 to current
Post #466476 29th Jan 2018 4:25pm
I've left my Td6 for 12 days recently albeit at home and it started straight away. If you are worried you can always fit a temporary battery in the boot for the duration and fit a battery isolator switch or indeed simply undo a battery terminal to the front battery. This arrangement will ensure that your car operates whilst parked from the temporary battery and will start from the fully charged front battery as normal when you need it. The other thing to ensure is that your key manually opens the drivers door correctly. If it doesn't and you return to a flat battery you have a further problem. Thumbs Up
Post #466480 29th Jan 2018 5:02pm
appj62
England 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Mine's normally on the drive for over 3 weeks at a time and starts OK, even in the depths of winter. Battery is an 020 and is 3 years old.
I'm at work now, so I've probably given it the kiss of death for when I get home next week Rolling Eyes Previous cars:
S-Max 2007-2013 (only diesel I've had, good car but expensive when diesely bits go wrong, so what's the point?)
Galaxy 2001-2007
Mondeo Estate 1997-2001
Sierra Estate 1993-1997
Uno Turbo 1987 -1993
Fiesta 1984 - 1987
Fiat 127 1982 - 1984
Post #466483 29th Jan 2018 5:12pm
mpirie
If you're leaving the car where there is daylight or fluorescent light, you could plug a solar charger into the boot accessory socket and it'll keep the battery topped up.
Post #466507 29th Jan 2018 8:36pm
Gyre8
@mpirie. With my luck such a device will probably burst into flames, set fire to the car and then the whole multi-storey car park along with all then cars therein. Wait a minute....
Post #466553 30th Jan 2018 2:54am
wack61
Probably worth investing in one of the small lithium jump packs though I'd imagine the AA have a guy on standby as it must happen a lot
Solar charger if it's outside or you can get it at the edge of a multi storey
If you use valet parking just make sure they don't park it near the entrance Laughing
https://www.mirror.co.uk/news/uk-news/more...ck-8293746
Post #466563 30th Jan 2018 9:20am
