Home > Technical (L322) > Upper Glove Box lid MY07+ |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34959 |
it does sound like its all out of sync...your battery reset suggestion might do the trick... ... - .- -.
31st Jan 2018 9:36pm |
quavey Member Since: 22 Jan 2017 Location: Lancaster Posts: 297 |
Great will give that a try, I will follow the guide for the pyrotechnic battery disconnect thing etc. 2005 E60 M5
31st Jan 2018 9:39pm |
I have tried a battery off reset but to no avail.
2nd Feb 2018 7:07pm |
maybe a loose wire behind the button/switch? ... - .- -.
2nd Feb 2018 7:15pm |
Possibly, I've got the workshop manual and had a read through it for removing the glove compartment to get to the latch doesn't appear too bad although the switch is a little more tricky by the looks of things. I think I'm going to have to find a specialist to take it all to bits to see whats wrong.
2nd Feb 2018 8:31pm |
why not prise the button out and have a look... ... - .- -.
2nd Feb 2018 8:52pm |
Does it just prise out? I wouldn't want to risk damaging it further. Has anyone removed the button? 2005 E60 M5
2nd Feb 2018 9:01pm |
Does anyone know which fuse might control the latches? Feed the switches? 2005 E60 M5
2nd Feb 2018 9:21pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Yes, it just pulls out. Use a credit card or similar to protect the dash and small screwdriver and pry it out.
2nd Feb 2018 10:27pm |
Great stuff thanks for that.
2nd Feb 2018 10:40pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2230 |
Only Landroverr would ave a switch that needs programming |
2nd Feb 2018 10:44pm |
Yeah, I don't think its the actuator either. Its just a solenoid.
2nd Feb 2018 10:49pm |
Well that took the grand total of 9 seconds to remove. Jesus, looking at the LR manual its about 20 hours labor.
2nd Feb 2018 11:01pm |
2012 are different dashes and instruments. The part No states from 2007 to 2009, so I would guess not. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
2nd Feb 2018 11:05pm |
