Home > Maintenance & Mods (L322) > 20" RRS Stormers on my L322 FFRR - advice please
MI6
2003 Range Rover HSE Td6 Java Black
Hi everyone. I have a java black FFRR L322 HSE Diesel 03. It has 18" standard LR RR alloys.
It currently has a problem with the air suspension stating inactive and not moving up and down from the switch. However the ride is fine but if battery low or very cold the rear arches do go down a little.
Will it be okay to put on Range Rover Sport Stormer 20" alloys (with Achilles ATR Sports 255/35ZR20 97W XL tyres fitted)?
Thanks in advance for any advice.
Post #46739 20th Jan 2011 1:40pm
dan_uk_1984
The profile on that (35) is consderably lower than the standard tyre and will givea very uncomfortable ride. If you want 20" Alloys go for the propper ones meant for the car Thumbs Up I believe the offset is also different as are the wheel nuts.
Post #46745 20th Jan 2011 2:01pm
you have the black nuts with the smaller shank, if you change to 2006 onwards FFRR or RRS wheels then you'll need silver nuts with a 23mm shank..
i have RRS wheels on mine with 295/45/20 tyres and the ride is ok, the most common RRS tyre size is 275/40/20 which a lot of FFRR owners have...there is a difference in the offset but its only 4 mm [i think] and the wheel wiil be 9/9.5J as opposed to the FFRR which is 8/8.5j so the RRS wheel will stick out a little bit more and fill the arches better...
Post #46753 20th Jan 2011 2:51pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
Ohh errrr scarey.. Rolling with laughter Ash
2016 SDV8 AB
Post #46781 20th Jan 2011 4:03pm
i know after i writ that someone would make a comment.. Laughing
Post #46784 20th Jan 2011 4:09pm
Jsb
I have a set of stormers, not originals with tyres same size as scary that I am not using. They need a refurb but are yours 300 if you come collect? 2 tyres are brand new and 2 are about 3000 miles on them.
Post #46788 20th Jan 2011 4:32pm
MI6
So basically the advice is to avoid the wheels and tyre combo but if i really want RRS wheels then to change to tyres as near 50 profile as i can get.
Thanks guys, decision made Thumbs Up
Post #46789 20th Jan 2011 4:34pm
MI6
Might be interested, please could you give me full details and pics if possible?
Post #46790 20th Jan 2011 4:36pm
Jsb
i dont seem to be able to upload any files to my gallery, can you PM me your email address and I will send them over.
Post #46795 20th Jan 2011 5:49pm
