Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix
Page 12 of 36 <123 ... 111213 ... 343536>
thanks nino, i'm up for the challange Shocked Laughing ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #467572 6th Feb 2018 5:00pm
nino_nino
you know you have all ffrr team behind you.
and Mikey, don't you get all sunburned now, on those beautiful Tenerife beaches. Very Happy Thumbs Up
Post #467578 6th Feb 2018 5:32pm
GGDR
o-ring job is dead easy Stan
. Cheers, Greg
Post #467626 7th Feb 2018 2:50am
thanks greg, but it's my articulation which is the problem...luckily i have persuaded 'number one son' to help... ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #467628 7th Feb 2018 7:52am
mpirie
It's sometimes not that easy to tell if the leak is coming from the oil cooler or the turbo pipe.
The oil runs down the bell housing in both cases. You really need to pull the inlet manifold etc off so you can look directly down on the cooler. If it's failed, then it'll be surrounded by oil.
Post #467640 7th Feb 2018 10:43am
information digested, thanks Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #467643 7th Feb 2018 11:00am
Sandyt
Hope he isn't going to charge main dealer rates - mine seem to Laughing
Post #467647 7th Feb 2018 11:31am
i've trained mine to be happy with a bacon butty Laughing ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #467649 7th Feb 2018 12:32pm
i've at last had a look at the leak and now need expert opinions on whether its the 'o' ring thats leaking and pushing the oil up [arrowed] or the oil cooler above it, what do you think?
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #468111 11th Feb 2018 2:31pm
Baltic Blue
It will only take your mechanic son half an hour to change the Orings, so what’s to loose?, change them and see if it stops leaking would be my choice.
How did it come to your attention?
Oily patch on drive/ garage floor or burning oil smell?
If you think it is still leaking after changing them you have still got the Warranty to get the cooler/ gaskets looked at.
Post #468112 11th Feb 2018 2:49pm
nino_nino
it looks very much like top gasket is leaking, and I would replace both once you are at it.
and once you have air intake plenum off may as well clean it inside. easy but very messy job. Thumbs Up
.Nino,
Post #468113 11th Feb 2018 2:55pm
@mike, my thoughts are the same , change the 'o' rings and see if the leak comes back but looking at ninos pics it looks like the oil gasket is the culprit ..
it was the smoke and oil burning smell that brought it to my attention..
@nino, as its going in for the leak under warranty ,i'll let the dealer sort the oil cooler problem and i'll have a bash at the 'o' rings.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #468115 11th Feb 2018 3:11pm
Baltic Blue
Nino, not only are you a very skilled mechanic, but you are a brilliant photographer 👍👍
Stan, If you can’t get it booked in until end of March, then I would go ahead and change the O rings , even as Nino says it looks likely to be the gaskets/ cooler.
Tell him it is payback for his lift from the airport 😁😁. G reg 2.5VM Vogue Portofino red 1991- 1999
Post #468117 11th Feb 2018 3:26pm
nino_nino
Mike, I was a fashion photographer for few years while living in Chicago (1980-1999), Pay was so so but the other benefits were great . Twisted Evil
Post #468119 11th Feb 2018 3:59pm
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
How big a job is it to remove the inlet manifold and change the oil/water heat exchanger?
Is there a wiki or manual that explains it in detail?
Post #468124 11th Feb 2018 5:09pm
