Home > Technical (L322) > Freon weight help
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Freon weight help
Could someone help me confirm which amount of Freon is supposed to be in the air conditioning system, please.
I’m a bit confused with this label. Is this referring to 2 and 4 zone climate?
If so, how do I know what I have (I have rear fan assist on the front console and 2 dials/knobs on the back of the centre console). I think I have two zone, but just want to confirm.
Any help appreciated
Cheers
[/img] 2007 3.6 TDV8
Post #468679 15th Feb 2018 4:48am
Spooky
United Kingdom 2014 Range Rover Autobiography 5.0 SC V8 Corris Grey
Yep - only one air-con system, so 750g of R134a required. Regards,
Mick
'Bertha' - 2014 SDV8 Autobigraphy
'Vincent' - 2010 TdV8 Vogue SE
- 'Molly' - 2005 HSE Auto
'Dixie' - 2000 D2 Td5 ES
Post #468680 15th Feb 2018 7:31am
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
Air con
Hi, you only have one air con unit but extra pipework hence more gas weight, I think they produce one sticker that will fit all cars?
Post #468690 15th Feb 2018 10:38am
cheezels
Ok cool, thanks for that 2007 3.6 TDV8
Post #468699 15th Feb 2018 12:31pm
DavidS
Spain 2007 Range Rover Vogue SE TDV8 Java Black
Interesting, my 2007 has climate seats front and rear, does that make a difference?
Post #468729 15th Feb 2018 3:04pm
Rob99
Climate seats make no difference as they don't have AC circuits in them, just some clever peltier cells.
As I understand it, with 4 zone AC there is additional pipework and a separate evaporator unit for the rear cabin, hence the larger refrigerant volume.
You can tell if you have 4 zone by seeing what the controls are on the rear of the centre console. If you have 3 dials and the 2 outer ones have temperatures then you have 4 zone AC.
@ cheezels - as you say you have 2 dials then you must have 2 zone AC.
There's a picture of the different configurations in the owners manual (2010-2012 version) 2017 4.4 SDV8 Autobiography
2012 4.4 TDV8 Westminster - Gone, but not forgotten
Post #468754 15th Feb 2018 6:10pm
cheezels
Thanks Rob, ‘twas what I was thinking.
What got me questioning myself was the amount of Freon recovered equaled the amount for a 4 zine vehicle.
Looks like it’s been overcharged at some point 2007 3.6 TDV8
Post #468791 15th Feb 2018 10:31pm
There is an easy reference point... If your car has a 1” deep arm rest cubby box then it has 2 X aircon fitted Thumbs Up
All the gubbins gets hidden under there and you loose your cubby box Rolling Eyes
Post #468798 15th Feb 2018 11:26pm
