Home > Technical (L322) > Auxiliary heater |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
7th Dec 2017 10:19am |
GavinBell Member Since: 10 Sep 2017 Location: Phnom Penh Posts: 88 |
Had a similar problem - but with remote. Sorting a CTEK to keep battery topped up ...
7th Dec 2017 3:03pm |
westminster 62 Member Since: 03 Oct 2017 Location: essex Posts: 20 |
Many thanks for your reply, have started engine and after 3mins like you said warmer air comes out of the face vents, although couldn't hear any clicking noises coming from back of car just a quite loud humming noise from near the the battery compartment have set timer for later on today and will see what happens, I checked the voltage on the battery and it is reading 11.89 volts which probably doesn't help, I don't understand why It isn't possible to switch on the FBH manually from the display screen.
8th Dec 2017 10:02am |
GAC23 Member Since: 27 Nov 2013 Location: Herts Posts: 670 |
To jump in here ... Can you set the temp higher than you've shown? And does it matter if the recirculation is set to auto? What do I put here then? |
8th Dec 2017 11:36am |
Westy,
8th Dec 2017 12:03pm |
Thanks, will give it a go.
8th Dec 2017 12:35pm |
Haven't checked battery before as car has always started first time, pretty sure it is the original battery, I only use this car at weekends, so isn't used that regular. |
8th Dec 2017 1:58pm |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 761 |
On the 17 minute cycle it won’t make the interior toastie
9th Dec 2017 7:30am |
That could be my ‘problem’ then
9th Dec 2017 12:31pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
For me getting 'toasty' is all about setting the timer to perfectly align with the time you jump in the car.
9th Dec 2017 1:02pm |
Last night set the FBH timer for AM 7:30, this morning heater started right on time, fuell pump clicking turbine spinning OK, run for full 20 min. and stop. outside temperature -4C inside 6C after heater run. so not very 'toasty'. can somebody else do the same thing- mesure temp outside and inside after heater run. would be nice to compare |
10th Dec 2017 10:54am |
I haven’t measured it.
10th Dec 2017 11:13am |
Have got my local Range Rover specialist to have a look, and have been told there has been a technical bulletin issued by Land Rover regarding the FBH and needed a software update which they have done, it is now working fine. |
17th Feb 2018 5:46pm |
