Home > Technical (L322) > Suspension Fault |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34927 |
drill a hole in the compressor filter, that might help.. ... - .- -.
17th Feb 2018 6:07pm |
Silversurfer13 Member Since: 17 May 2014 Location: London Posts: 83 |
Ah Pal.... I feel for you
17th Feb 2018 6:35pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2215 |
As Stan says first thing to do the compressor has a filter which inhibits the air being expelled from the compressor as it vents - the filter is full of silica or something similar and it breaks down and forms a dust which prevents the vented air being released so the vehicle goes into extended mode and you get a christmas tree of faults |
17th Feb 2018 7:03pm |
The filter silica dries the air on the way in and the expelled warm dry air dries the silica on the way out so that is what it is there for |
17th Feb 2018 7:05pm |
Donimo Member Since: 28 Aug 2017 Location: Manchester Posts: 16 |
Thanks, Gents. This was helpful, and will give me a focus for some investigation tomorrow. Current: 2007 RR 4.2 SC, now deceased, written off by an X5
17th Feb 2018 8:18pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
To avoid confusion:
17th Feb 2018 8:21pm |
Thanks Joe exactly so my fault |
17th Feb 2018 8:30pm |
So don't just drill everywhere!
17th Feb 2018 8:52pm |
this is what i was referring to,
17th Feb 2018 10:02pm |
That's even more information in that thread, Stan. Off the top of your head, is this a simple job (drilling the filter nut) that does not require the battery to be disconnected? Current: 2007 RR 4.2 SC, now deceased, written off by an X5
17th Feb 2018 10:59pm |
To save you dismantle the silica filter once you have the brass silencer off cycle the suspension a couple of times and a heap of white dust will come out it is this that blocks the silencer and drilling stops the build up in the future |
17th Feb 2018 11:12pm |
Update:
19th Mar 2018 6:01pm |
Aah... you don't have the easy lifting straps fitted
19th Mar 2018 6:37pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
19th Mar 2018 8:51pm |
