Home > Maintenance & Mods (L322) > Fog lights Ballast?
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
Fog lights Ballast?
Hi all
By process of elimination I reckon the Ballast that’s fitted to foglight wires when I fitted DRL’s has packed up putting up a check fog lamp error. .
I’m trying to find a replacement but all are located in China and delivery in April!
Anyone know what else it could be called or what ohms etc I need?
I’m searching T 50W 8RJ.
Can find 6ohm ones in UK £8.99 for 2. Are they the ones?
Cheers Accept, some days your the pigeon, some days your the statue!
Post #469024 17th Feb 2018 4:55pm
instead of the resistor you could wire up a small bulb or if you have an iidtool you can switch off hot& cold monitoring.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #469028 17th Feb 2018 5:05pm
See here:
https://www.ebay.co.uk/sch/sis.html?_itemI...4099.l9146
You want 50W 6ohm
Follow this thread
http://www.fullfatrr.com/forum/topic10160.html .
Post #469029 17th Feb 2018 5:10pm
Boydonegood
As always, yous are stars. Thanks so much.
Just tried replacing the resistor with a side light bulb and holder but still same error on dash. Is making connection as lights up when turn fogs on!
Checked it with Icarsoft and was originally “right hand foglight”. Swapped the resister with other side and the fault moved with it... so presuming it’s that.
I’ll order the ones you’ve linked
Thanks so much guys.
Tel Accept, some days your the pigeon, some days your the statue!
Post #469033 17th Feb 2018 5:45pm
Can't switch off cold monitoring on '02-'05 models .
Post #469043 17th Feb 2018 6:24pm
olliecat2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
I,m not sure why but for the last week I have been getting the error message check front fog lights . I have checked and they work. Perhaps the cars turning psychic
Post #469475 20th Feb 2018 6:27pm
Discotigger
I occasionally get either a 'Check Front Fog Light' or 'Check Dip Beam Light' when I turn the lights on of a morning. It only happens when it's really cold (e.g. -2C this morning) so I think it's just the cold weather affecting the resistance of the wiring, as both the Fogs and Main Lights work perfectly.
Just another of the Fattie's foibles!!!
Post #469568 21st Feb 2018 2:15pm
Boydonegood
Mines now every time I start or turn off. As say, I swapped ballast and the fault (according to icarsoft) swapped with it. Just waiting on replacement to arrive and will update! Accept, some days your the pigeon, some days your the statue!
Post #469584 21st Feb 2018 4:56pm
