Home > Technical (L322) > detachable towbar Q? |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1227 |
Check it is not in the storage cubby under the rear boot fuse area! Tom
14th Aug 2017 8:42am |
bembo449 Member Since: 26 Jul 2017 Location: lincolnshire Posts: 800 |
After a bit more research , turns out the farmers hitch is the fitment i will need as the swan neck attachment is missing too ! Alot cheaper to buy but even easier to make , so ive bought some box section and will knock a couple up later |
14th Aug 2017 5:48pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7814 |
Be very careful - they (clearly) won't be VOSA approved, therefore will invalidate your insurance as well as making you leagally liable should the worst happen.
14th Aug 2017 8:03pm |
Interesting alistair , especially as im copying the westfalia design specs for said farmers hitch |
14th Aug 2017 8:33pm |
My mistake - I incorrectly assumed you'd bought the box section to use for the tow bar
14th Aug 2017 9:29pm |
Now thats a good question ? I really want to be able to take it off after use but will see which works best in the real world alistair |
14th Aug 2017 9:32pm |
I had 3
14th Aug 2017 10:08pm |
Good info alistair , thanks , i reckon in the end i will use a pin as its just asking for it to be stolen if i leave it attached |
14th Aug 2017 10:12pm |
nicam Member Since: 23 Nov 2016 Location: Lancashire Posts: 9 |
Please could anyone give me information on the spec for the (later) type bolt fixing.
20th Feb 2018 3:17pm |
Is it more than a couple of thick washers would take care of ?
20th Feb 2018 3:32pm |
And whilst I'm posting photos, here's the threaded vs smooth -
20th Feb 2018 3:39pm |
Alistair,
20th Feb 2018 10:13pm |
Is your insert piece threaded - like my 3rd picture ?
21st Feb 2018 8:34am |
Thanks, Alistair - I will do a bit more searching,
21st Feb 2018 10:03pm |
