Home > Maintenance & Mods (L322) > Antifreeze, how do you check yours?
Andyyav
United Kingdom 2007 Range Rover Vogue TDV8 Zambezi Silver
Figured I’d better check my antifreeze value with this Cold stuff coming, anyone have an easy test point / process they use?
I have the turkey baster type and stick the hose part in the bleed screw but have differing success!
Post #469872 24th Feb 2018 8:59am
TJH1985
The car usuall requires some work yearly that requires the coolant dropped, we always refill with new at 50% so I’m confident it’s up to spec Rolling with laughter
Prior to that it had the common TDV8 cracked thermostat housing, so was a ongoing change Censored
Post #469969 25th Feb 2018 8:54am
Vogue
We test our vehicles with One of these :-
https://rover.ebay.com/rover/0/0/0?mpre=ht...2934193216 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #469973 25th Feb 2018 9:18am
Andyyav
@Vogue I have something similar, how do you collect a sample?
I refilled recently so am confident in the strength just curious on the best method
Post #470016 25th Feb 2018 4:12pm
Vogue
Just suck a bit out of the cooling system expansion tank 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #470035 25th Feb 2018 7:37pm
Andyyav
Yep I find I have to wait till it’s warm then open the filler and the bleed screw to raise the level enough to get some out, then when finished I have to bleed the air out again, just wondered if there was a better way
Post #470041 25th Feb 2018 8:42pm
nino_nino
Andy, ad piece of plastic/rubber tubing to turkey baster,
Car is equipped with "specific gravity sensor" - weighted float for the proximity switch which alerts us of low level/quality of the coolant.
Post #470118 26th Feb 2018 10:24am
Baltic Blue
You have taught me yet another gem Nino.
I didn’t know it checked SG as well as coolant level. Thumbs Up Thumbs Up
Post #470127 26th Feb 2018 11:55am
nino_nino
Mike, I'v learned that on this forum and tested It when I had my expansion tank off for cleaning. filling tank with just water resulted in a warning, adding antifreeze OK .
Post #470147 26th Feb 2018 2:00pm
Baltic Blue
QED. Bow down G reg 2.5VM Vogue Portofino red 1991- 1999
Post #470154 26th Feb 2018 2:32pm
