Home > Maintenance & Mods (L322) > A/C Compressor Noise? - Changed to Other Noise! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
I think my air con compressor has gone south!
26th Feb 2018 11:15am |
Clive603 Member Since: 21 Jun 2016 Location: Sussex Posts: 35 |
Sounds like clutch & pulley assembly problems. Likely the pulley bearings have gone west so its not properly aligned even when the clutch is engaged.
26th Feb 2018 12:32pm |
Thank chaps. Too flaming cold and snowy to do any lying around on the drive under the car at the moment. I am guessing I can do the swap myself if I get the system degassed... .
26th Feb 2018 12:52pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
Jo, In the meantime turn the AC off if you gonna wait for some sunshine and warmer temps. |
26th Feb 2018 1:49pm |
@ Nino good point .
26th Feb 2018 3:10pm |
OK its Captain Obvious speaking but surely you have checked that the electromagnetic clutch and pulley assembly are still firmly attached. I've seen the odd report of the centre bolt working loose or even falling out completely.
26th Feb 2018 6:20pm |
As said too cold to roll about in the gravel, but will check tomorrow before driving anywhere... .
26th Feb 2018 6:39pm |
Hmmm
2nd Mar 2018 11:35am |
