Home > Technical (L322) > 4.4 tdV8 FAULT HISTORY LOG |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3677 |
Thanks, and good luck sorting the restricted performance problem.
19th Feb 2018 10:56am |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Hi Mike,
. Grateful for any tips or further info on this. Greg Cheers, Greg - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - 2011 Vogue SE 4.4 with lots of toys in Stornaway |
2nd Mar 2018 9:51pm |
Greg,
2nd Mar 2018 10:13pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
I have the same error massage Greg, apparently it is's not something to be worried about. people have replaced the sensor but the fault comes back.
2nd Mar 2018 10:16pm |
Fatfred Member Since: 15 Dec 2017 Location: essex Posts: 50 |
Try spraying a good egr cleaner down the air intake for starters, just a thought FF TDV8 WESTMINSTER EXTERIOR DESIGN PACK 2012 |
OtleyDominic Member Since: 01 Nov 2017 Location: Leeds Posts: 61 |
I have just had the EGR sensor replaced and seemed to clear the code and issue? |
2nd Mar 2018 10:23pm |
I've read a bunch of posts on this over the last hour and it seems some people have the fault, leave it and it's fine.
3rd Mar 2018 1:05am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Baltic, only just spotted this thread, I'll update with info soonest, but won't be till after the bank holiday, and only then when I get my IID tool and can find out if I have any as yet unknown gremlins.
22nd Aug 2018 11:26am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4231 |
Be good to have a stand alone topic in Technical that lists the common issues, how to check if they’ve been done and then a link to a thread/wiki on how they can be fixed... 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
27th Aug 2018 5:38pm |
John w Member Since: 14 Jan 2018 Location: Cranleigh, Surrey Posts: 439 |
I have had to repair the top near side strut wiring for adaptive dynamics a few months back, and also the PCV for the aircon pump.
27th Aug 2018 7:36pm |
John,
27th Aug 2018 8:41pm |
gg2201 Member Since: 21 Oct 2013 Location: Callington Posts: 158 |
So far issues:
30th Aug 2018 8:58pm |
Kit Member Since: 16 Sep 2018 Location: Shropshire Posts: 2 |
I've read about a similar coolant issue, it was the water cooled EGR leaking water into the intercooler, caused turbo failure |
16th Sep 2018 6:00pm |
http://www.fullfatrr.com/forum/topic48509.html
7th Oct 2018 4:01pm |
