Home > Maintenance & Mods (L322) > 4.4 TDV8 Oil Leak Fix |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
17th Feb 2018 10:35pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
what oil does the oil cooler cool, engine or auto box? ... - .- -.
19th Feb 2018 11:38am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2308 |
Engine oil. The gearbox oil cooler is oil to air. |
19th Feb 2018 12:01pm |
thank you G... ... - .- -.
19th Feb 2018 12:02pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3676 |
You beat me to it Graeme, the main engine oil filter feeds into the cooler as per picture,
19th Feb 2018 12:16pm |
muppet Member Since: 09 Nov 2016 Location: manchester Posts: 88 |
Just got mine back from garage, 4th attempt at fixing the oil leak, so far they have replaced the oil cooler, something else and now the turbo hose...still smells of burning oil but maybe residual from the leak..luckily still under warranty...
19th Feb 2018 7:00pm |
Sunseekertom Member Since: 25 Nov 2016 Location: Torquay Posts: 7 |
Hello!
5th Mar 2018 11:06am |
Kinger Member Since: 16 Feb 2018 Location: Somerset Posts: 11 |
I just noticed some oil drips on the last remaining patches of snow today, took a look and feel down the back of the engine, sure enough i have an oily hose end, ordered the o rings up , hopefully, i have time to do it before the weekend.
5th Mar 2018 4:39pm |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
I now have this problem too, smoke coming from under the bonnet and stinks through the air vents (no smell with air recirculation on).
6th Mar 2018 6:07pm |
The 2010-12 Workshop Manual is only available to members who have been active contributors for over 12months and with over 100 posts. G reg 2.5VM Vogue Portofino red 1991- 1999
6th Mar 2018 6:40pm |
Fair enough, i'll have to go with the ham fisted approach haha. 2011 RR Autobiography 4.4 TDV8 |
6th Mar 2018 6:43pm |
If I get down to the oil cooler will it be obvious if its cracked/knackered? Im hoping its just my oil feed pipes that need the o-rings swapping and its just residual oil elsewhere. 2011 RR Autobiography 4.4 TDV8 |
6th Mar 2018 6:50pm |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 895 |
It's not that obvious that the cooler is allowing coolant and oil to mix, unless oil starts to show in the coolant header tank.
6th Mar 2018 7:44pm |
Cheers, ill get the gaskets from Dan and do it in one go, assuming i can get it all apart. From a quick visual there looks to be a fair bit of stuff to remove/pipes/electrics in the way. 2011 RR Autobiography 4.4 TDV8 |
6th Mar 2018 7:51pm |
