Home > Technical (L322) > Sat navigation battery drain |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 |
Far from certain but it looks like my sat navigation doesn't turn off. I checked the red indicator light through out the day while the beast was parked and it never went off. So for the time being I pulled the fuse. So why does this happen? Is it the BCM, audio system or just the sat nav at fault? My logic 7 system is toast. Been running on half a radio amp and no secondary logic 7 amp for a while. |
29th Nov 2017 9:16pm |
I can confirm the satnav draining battery because it wouldn't go into sleep mode was due to a tested good but slightly aging battery and/or a 75% broken negative battery cable. It sleeps fine now. |
13th Mar 2018 8:51pm |
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 669 |
Always good when faults can be resolved without too much pain - lol.
13th Mar 2018 9:15pm |
Forgot to add that I did the amp repair with the two cheap amps but it still wouldn't go into sleep mode until the battery/ground repair. |
14th Mar 2018 12:59am |
