Home > Technical (L322) > HDC, Air Sus inactive + general alarm issue |
RaveRover Member Since: 14 Mar 2017 Location: Melbourne Posts: 36 |
G'day.
18th Mar 2018 9:30am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
Yup, most likely an ABS sensor or reluctor ring gone bad, given your symptoms.
18th Mar 2018 11:26am |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 |
Could just be that the front tracking is way out.
18th Mar 2018 11:53pm |
Hey Thanx guys for the valuable input.
19th Mar 2018 4:45am |
mm289 Member Since: 11 Mar 2016 Location: Hampshire Posts: 207 |
Just to add a quick check, pull the multiplug connector to the ABS ECU (front of the ABS pump block by the l/h suspension turret) and check for corrosion on the pins. Mine had this and caused similar symptoms.
20th Mar 2018 10:08am |
Ok, all fixed.. $2200 later..
17th Jun 2018 7:44am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
Trouble with mechanics replacing things in hope they fix things and they don't, so you pay for all those unnessecary parts you ddin't need.. |
18th Jun 2018 9:33pm |
