Home > Technical (L322) > Adaptive lights |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
They do their ' dance ' everytime they come on ๐ 2015 4.4 AB
22nd Mar 2018 10:12pm |
Steveo Member Since: 26 Jan 2015 Location: Essex Posts: 156 |
Hmm might have a problem then as I have only noticed it a couple of times |
22nd Mar 2018 10:16pm |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 |
On my 56 plate (MY2007) they do the calibration test when you start the engine 56 TDV8 Vogue SE
23rd Mar 2018 10:32pm |
I have just had a look and it only dose itโs thing when you start the engine I was thinking it done it when you turn on the ignition |
23rd Mar 2018 11:04pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
Steveo, the AFS system takes its data from the Air Suspension along with the gearbox and several other areas... Engine must be started to get this data sir |
23rd Mar 2018 11:40pm |
Cheers is there also a shutter in the headlights that moves when you select main beam |
23rd Mar 2018 11:53pm |
Yes there is, only moved when full beam is selected from dipped beam, NOT full beam flash as that only works the halogen full beam lights... |
23rd Mar 2018 11:59pm |
