Home > Maintenance & Mods (L322) > water in boot |
elpeede Member Since: 09 Mar 2010 Location: Staffordshire Posts: 713 |
I had read of some leak points on the side windows but never got to the bottom of it fully. If you look at the rear side windows where the lower seal meets the C - pillar there may be a slight gap. I filled my gap both sides with some black flange sealant (I love that word!) and then tided it up so there was no excess using a baby wipe so as not to have sealant on the paint. I've not noticed any damp since. I only did mine after the MKIII nav died and the moisture appeared to have run directly in to the MKIII nav
24th Jan 2011 10:41pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1652 |
Hi Daveo,
24th Jan 2011 10:49pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3059 |
I have traced the ingress in mine to the bottom of the rear-most edge of bottom of the boot and spare wheel area (nearest the bumper) where the top and bottom bits of metal are crimped together. It comes in only from the left hand corner and the middle.
25th Jan 2011 12:43am |
Just a suggestion and I admit it does not solve the "real" issue, but might it be worth drilling a couple of drain holes where the water accumulates in the wheel well area.?
25th Jan 2011 10:53am |
Whilst fitting my towing electrics I noticed there is an oblong hole behind the bumper. About 2 inches x 1 inch... This should have a rubber grommet in it, mine didnt. Mine had some black gaffa tape stuff, but exactly the same type that is used in different places throughout the car - ie factory fit.
25th Jan 2011 11:33am |
Interesting - rather suggesting that water is being thrown up into the car instead of dripping down into it.
25th Jan 2011 12:33pm |
I think with the position of this both could happen.
25th Jan 2011 12:39pm |
