Home > Technical (L322) > Tdv8 3.6 6 speed gearbox issue |
lazylabs Member Since: 01 Nov 2016 Location: Lincoln Posts: 78 |
Hi
25th Mar 2018 4:01pm |
Thanks for the reply..
25th Mar 2018 6:56pm |
unsolicited Member Since: 30 May 2016 Location: London Posts: 123 |
Try first resetting ENGINE adaptations (NOT gearbox adaptations) with the IID tool. Let the car re-learn and see how it goes.
25th Mar 2018 7:03pm |
chefkenmore Member Since: 11 Jan 2015 Location: Fearnan perthshire Posts: 702 |
Watch the revs? 1800-2000
25th Mar 2018 7:04pm |
I'll give the engine adaptations a reset thanks.. How did yours come about?
25th Mar 2018 11:39pm |
Just exactly that, pulling uphill with the caravan on the back!
26th Mar 2018 9:27am |
If I did an engine reset, would it forget the Alive remap?
26th Mar 2018 9:29am |
Adaptations? I doubt very much that would affect a map. |
26th Mar 2018 6:07pm |
re: How did mine come about. The answer is I don't know, since it did it from when I bought the car at 9 years old. It was fine in manual mode but would try very harsh downchanges when approaching kickdown on the accelerator. Enough to make you wonder if the gearbox had lunched itself.
26th Mar 2018 6:15pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
Incorrect gear ratio faults require further investigation than just a judder... |
26th Mar 2018 7:12pm |
Yeah, that fault is worrying. Mine never logged any faults whatsoever. Solenoids? |
26th Mar 2018 7:23pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16179 |
I’de start with the software... Have you tried any kind of updates? |
26th Mar 2018 11:55pm |
Not tried any updates as yet..
27th Mar 2018 9:06pm |
@cam-tech-craig...
27th Mar 2018 9:07pm |
