Home > Maintenance & Mods (L405) > First Service (and Ad Blue) |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7770 |
Should be at least double that - more like 15k or 12 months
17th Apr 2018 2:14am |
ADI Member Since: 13 Oct 2017 Location: South Yorkshire Posts: 70 |
This will be an "oil service".
17th Apr 2018 8:00am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1342 |
Is it possible that diesel is being dumped into the engine oil due to a diet of short runs from cold etc (also leading to higher AdBlue use) and that resulting deterioration of that oil is causing the car to tell you that it needs an oil change service? I'd be getting the dealer to check that. Only Range Rovers since 1988 |
17th Apr 2018 12:06pm |
GadgetBazza Member Since: 16 Apr 2018 Location: Essex Posts: 8 |
Thanks all, I will check the service menu later today.
17th Apr 2018 12:10pm |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3694 |
Only done 8k miles and not needed a top up yet - note to self I had better check the current position 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
17th Apr 2018 1:02pm |
Right, managed to find the service info menu now. Never tried looking without the engine turned on, and it doesn't show up when it's running!
17th Apr 2018 2:53pm |
OK, dealer says it's a known issue for my car once they took the registration. Apparently there is a software issue that mis-calculates the details that will fix this.
17th Apr 2018 3:16pm |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2152 |
Be very careful. These messages are usually triggered by oil dilution with diesel as a result of incomplete DPF regeneration cycles. Your car may be crying out for an early oil change (which is usually paid for by LR) as the oil may now be knackered
17th Apr 2018 7:42pm |
Agree with CS and Red Merle re. the oil dilution. Very dependant on type of journeys.
17th Apr 2018 8:39pm |
Thanks all,
18th Apr 2018 1:36am |
Do bear in mind that the AdBlue and DPF are two completely separate systems on your car.
18th Apr 2018 6:55am |
Hi Red Merle
18th Apr 2018 10:49am |
Andrew,
18th Apr 2018 12:56pm |
Thanks
18th Apr 2018 1:20pm |
