Home > Maintenance & Mods (L322) > Blue Spark installation after a re map?? |
jaysta10k Member Since: 24 Aug 2017 Location: Cheshire Posts: 294 |
Has anybody got any input on this please......Just want to know if I can fit a blue spark chip box to my TD6 after a re map and EGR delete if so will it give me even more performance or make no difference. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
23rd Apr 2018 8:28pm |
no idea, but a good performance remap will optimise the fuelling and injectors to get the most performance out of the engine. Adding a tuning box into the mix which basically tells the injectors to dump more fuel into the car can't be a really good idea, and the other issue is the chocolate gearbox attached to the engine, it isn't the happiest piece of kit with the standard engine tune, adding a remap and then a tuning box into the mix may result in premature detonation........
23rd Apr 2018 8:42pm |
Hi yep I get your point already had a recon gearbox at 123000 lol. Range Rover Vogue SE 4.4 SDV8 SVO Stying Pack
23rd Apr 2018 8:53pm |
gettingold Member Since: 03 Apr 2018 Location: Wiltshire Posts: 284 |
As stated above, personally save your money and put the good fuel in or spend it on a decent air filter.
24th Apr 2018 7:55am |
