Home > Maintenance & Mods (L322) > rear windows |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34914 |
do they operate ok from the rear switches ,if so it might be the front drivers switch pack thats faulty... ... - .- -.
26th Apr 2018 2:05pm |
TerryT-J Member Since: 02 Sep 2013 Location: Johnston, Pembrokeshire Posts: 86 |
I had the same problem. It was basically the lack of use! The glass was stuck in the rubber and was helped down. I used a little rubber grease in the window rubbers and seemed to do the trick. |
26th Apr 2018 2:15pm |
Balloonengineer Member Since: 03 Sep 2017 Location: Kent Posts: 171 |
The front and rear window switches create the same problem. Looking at the wiring diagram, (p37-39) the front set of switches operate the BCM, so bypass the rear switches, so perhaps that discounts the switches?
26th Apr 2018 2:54pm |
Before I greased the rubbers (ooerr missus) I could hear the window motors making a bumping sound so I’m assuming that was the anti trap kicking in when trying to wind them down. |
27th Apr 2018 9:01pm |
