Home > Maintenance & Mods (L322) > [SOLVED] Remote Locking/Unlocking not working |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6405 |
Car left for five days not long after fitting new battery
28th Apr 2018 12:03pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35114 |
battery reset and replace remote battery, or buy a new FF.. ... - .- -.
28th Apr 2018 12:29pm |
Disconnecting battery tomorrow, so we will see, also have a new fob battery so will install that too .
28th Apr 2018 11:35pm |
Neither battery disconnect or new battery in fob has made any difference.... .
1st May 2018 11:12am |
MR GLOVER Member Since: 03 Jan 2015 Location: grimsby Posts: 599 |
auto sparky is needed...................... i know you like to do every thing your self tho joe good look |
1st May 2018 7:26pm |
Good one stwid!
14th May 2018 8:32pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Mine did that after I had been tinkering. Turned out to be a blown fuse. Test the receiver for voltage ( the cassette like thing in tailgate). If no power then probably the fuse. Not sure where exactly but it's in the rear fuse box. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
15th May 2018 12:09am |
uzp315 Member Since: 19 Nov 2017 Posts: 428 |
After a recent flat battery I had to resynch the keys to the BCU. Not a complex task, but it doesnt always seem to register the key and I had to try dozens of times and over three days before I got a key to synch again. A real flaky process. Might be worth persevering.
17th May 2018 7:28pm |
Thanks for the tips, will hopefully get to the bottom of things over the weekend .
17th May 2018 8:58pm |
RESULT!
21st May 2018 12:11pm |
Did you get this to work consistently or was it still a pain? I'll have another go at some point and see if I can get both keys working. Presently it is one or the other. |
21st May 2018 5:30pm |
As I say, took 6 or 7 goes, key to position 1 a couple of times, making sure lock button pressed three times inside 15 seconds etc.
21st May 2018 7:10pm |
SilverParrot Member Since: 09 Aug 2018 Location: Herts Posts: 25 |
Excellent, worked first time for me after flat battery.
14th Mar 2019 8:57pm |
bgennette Member Since: 13 Jan 2013 Location: Newcastle Posts: 74 |
Winter is approaching here in the great south land and all old batteries are dying. Our daughter's Toyota Rav 4, my partner's VW Golf and my L322 remote key fobs all quit within a week. All 3 use the same battery - 20mm diameter, 1.6mm thick, 3.4 volt (nominal) lithium cell - aka 2016 coin cell. The Rav and VW retained settings during change over, but not the Range Rover. So, on to the wiki to read the re-sync instructions. After failing a few times I did some research and here is the result -
16th May 2019 7:54am |
