Home > Technical (L322) > Steering wheel reach
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
My steering wheel reach adjustment hasn’t worked since I’ve had the car. Whilst trying to sort another issue with brake lights tonight I found this dangling around the peddles.
Is this going to be an easy repair by reattaching the reach motor or is it a more complex job?
Post #478523 15th May 2018 9:23pm
Zebedee
United Kingdom 2004 Range Rover Vogue 4.4 V8 Bonatti Grey
There are 2 motors - one for the in/out and one for the up/down. The in/out motor is held on with a white plastic clip that easily breaks and can cause the motor to fall off (whcih looks like what has happened to yours) - You can't get the plastic clip, though i have seen people fabricate something to fix this problem. The other problem with this motor is the black plastic nut can strip its thread - so check that too.
The up/down problem is caused by something different - the lugs that hold the (brass) nut can break off.
 2004 4.4 Vogue (BRC LPG)
Sold: 2000 4.6 Vogue (BRC LPG)
Sold: 1981 In-Vogue
Sold: 1980 Ex-Army LWB
Sold: 1976 LWB
Sold: 1968 SIIA
Post #478555 16th May 2018 10:08am
SidewaysMatt
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Mine did the same early last year. As said, you can't get the white plastic mount separately. I used a couple of heavy duty cable ties to lash it back into position, and touch wood, it's been fine since. Is a very uncomfortable job to do though! 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #478601 16th May 2018 6:36pm
SidewaysMatt
Like this... 2004 Vogue TD6 - Remapped Smile
1998 Lotus Elise
Post #478602 16th May 2018 6:43pm
RRV78
Is this not the bracket I need?
https://www.island-4x4.co.uk/bracket-genui...28495.html
Post #478642 16th May 2018 10:12pm
Zebedee
Well I'll be.....
That does look like it - I've never seen just the clip on sale before. 2004 4.4 Vogue (BRC LPG)
Sold: 1981 In-Vogue
Sold: 1976 LWB
Sold: 1968 SIIA
Post #478717 17th May 2018 8:27pm
RRV78
I was on a well known auction site and happened to see one on there and was showing the land rover part number on the packet so googled it and this was cheapest place I found it.
Post #478718 17th May 2018 8:31pm
nicksaab
Thats the bracket you need QYH500030 - always been available, although not everyone stocks it. Although these days its a lot more expensive than it used to be - used to only be a fiver!
You will need to rummage around at the back of the carpet though for the steel rod which drives through it. It will be there- I found it sat on top of the carpet behind the pedals. (just spotted in your picture the rod is still in place)
You'll also need the force of hercules to put it in and once its in, its not coming out so make sure you have it set up. After an hour or so of contorting and fighting it I realised a long spark plug socket placed over the lug and a sharp tap got it in. Current Fleet:-
2012 RR 4.4 TDV8 Westminster
2004 RR 4.4 V8 Autobiography LE
2006 Mitsubishi L200 Animal
2004 Mitsubishi Shogun Warrior V6 LWB
Post #478738 17th May 2018 10:30pm
Site Copyright © 2006-2018 Futuranet Ltd & Martin Lewis
