Home > Maintenance & Mods (L322) > Seized ball joints |
Dano0404 Member Since: 28 Dec 2017 Location: Uk Posts: 44 |
Use a bigger hammer? You can get hydraulic ball joint splitters? Maybe try heating it up. |
19th May 2018 8:48pm |
scotcruz Member Since: 03 May 2017 Location: S C O T L A N D Posts: 391 |
Yeah I was thinking of getting a good hammer.. so far wasted £30 getting types of splitters and none of them worked.
19th May 2018 9:02pm |
Duplicate Post Current:
19th May 2018 9:03pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1698 |
OxyAcetelene to heat the hub
19th May 2018 9:19pm |
So sounds like a hub out job.. plus where would I get the oxyacetelene? Thinking might be cheaper to get a replacement hub Current:
19th May 2018 9:22pm |
Then you have the same issue when replacing ball joints in the replacement hub...
19th May 2018 9:23pm |
Agree.. any hints and tips.. where can I get the oxyacetelene? Current:
19th May 2018 9:30pm |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Local garage would help out with heat torch for a few pounds if you get the hub off. |
20th May 2018 9:22am |
Thanks.. that's a good shout..
20th May 2018 10:08am |
Driveshaft can be a right to get out
20th May 2018 10:27am |
Oh dear.. Mikey.. that's scared me off big time.. lol..
20th May 2018 10:39am |
I’ve always managed, but I do have an equipped workshop
20th May 2018 12:18pm |
I have all the tools.. just not got a decent torch. Would have been gr8 if I had access to a ramp.
20th May 2018 1:05pm |
36mm bi-hex |
20th May 2018 2:36pm |
