Home > Technical (L405) > Clicking noise when turning left |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
CV joint? |
27th May 2018 10:33pm |
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 860 |
Resurrecting this. I’m having this sound from passanger side rear when turning left. Sounds like a pebble is rattling around inside my wheel/tire. I’m guessing bad CV joint? How hard is this to repair on these rigs? DIY? 2014 FF Autobiography 5.0 SC
26th Jun 2021 9:24pm |
knwatkins Member Since: 11 Sep 2020 Location: Poole, Dorset Posts: 735 |
I also have this, when turning right. I noticed it a few weeks ago and thought it must be a stone in the tread and noticed it again yesterday. I haven't actually checked the tread of the tyre for a stone though. Kev
26th Jun 2021 9:53pm |
It definitely has to be suspension related. Bc it Only happens when turning left. I tested in a parking lot going in circles at slow speed and it would start from medium through full tight to the left. I need a buddy to see if it’s the front or rear. Nothing when I turn right.
27th Jun 2021 9:04pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7908 |
Drivetrain, not suspension.
27th Jun 2021 10:35pm |
28th Jun 2021 4:06pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
i had this noise with my L322, turned out to be the lower suspension arms... ... - .- -.
28th Jun 2021 4:21pm |
Was that a tick, tick tick noise Stan or just one tick when you turned...?
28th Jun 2021 7:58pm |
it was a repeat click Pete..i drove on full right lock and my son walked beside the front off side wheel and diagnosed the lower arm bush.. ... - .- -.
28th Jun 2021 9:32pm |
Mine is a repeated tink/click for as long as I’m turning left. Once I straighten out or turn right it stops.
28th Jun 2021 9:40pm |
same as you..clicking went when the steering wheel was straight...
28th Jun 2021 9:44pm |
Hmm ok. I’ll need to have another set of ears listen for me to determine location 2014 FF Autobiography 5.0 SC
28th Jun 2021 9:45pm |
Should be easy to check the arm for play to confirm... Pete
28th Jun 2021 11:31pm |
I suppose once jacked up and pulling on the lower control arm....if it has any play at all it would need rpelaced?
29th Jun 2021 1:46pm |
