Home > Technical (L322) > ACC retrofit to MY12 4.4 TDV8 help |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 |
I am sure I will this either get done by the friendly local dealer or with the help of GAPs team.
15th Jun 2018 2:55pm |
here we go, parts 1 and 2 - bracket and wiring loom are inbound at the local friendly.
19th Jun 2018 5:17am |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2307 |
I couldn't see anywhere in this thread where I mentioned that the radar unit needs a 10A fuse fitted to the engine bay junction box E17 slot. The graphic on the lid diagram will be recognised. Fitting the radar unit c/w fuse without re-configuring the CCF from CC to ACC will cause faults due to the unrecognised canbus messages so best to leave the fuse out until ready to change the CCF. |
19th Jun 2018 8:14am |
many thanks for this great info - surely safes a lot of nerves once done
21st Jun 2018 7:03am |
Nick Evans Member Since: 10 Dec 2013 Location: Dorset Posts: 10 |
Got mine all fitted & working but have not fitted a fuse yet ! Graeme can you confirm if your horn button works on the new switch because mine doesn’t thinking this maybe linked to the missing fuse ? My horn works fine on the right hand switch & with the original left hand switch but not the new acc switch. |
24th Jun 2018 1:02pm |
I'll confirm later when my wife isn't asleep but the wiring schematic shows that the fuse is solely for the radar unit. Hence I suspect that the electrical connector for the switch isn't fully home.
24th Jun 2018 9:42pm |
Later switches started at vin BA349700 according to Microcat.
25th Jun 2018 12:09am |
Bushy30 Member Since: 03 Jun 2018 Location: Oxfordshire Posts: 1097 |
Graeme,
4th Sep 2018 5:29pm |
Yes, QA/SS are just CCF parameters that can be set using the IIDTool. |
4th Sep 2018 9:58pm |
Thanks Graeme, play time tomorrow then
4th Sep 2018 10:09pm |
Simply reiterating warnings from others (GAP & BBS IIRC), which is a reasonable approach considering that LR reportedly didn't make this feature available on the L322 but possibly over-cautious if the feature was available on the first L405. |
4th Sep 2018 10:35pm |
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 385 |
I've been wondering about enabling this too. I'd be interested to see how it goes! 2010 4.4 TDV8 Vogue SE |
4th Sep 2018 10:40pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
What? Hidden features we can just turn on?
5th Sep 2018 7:11am |
Start/stop in this context is the same as queue assist whereby the vehicle can be brought to a stop then resume ACC on touching the throttle but perhaps the CC resume button. The couple of times that I cautiously allowed the vehicle to be stopped to test the feature, I didn't subsequently resume ACC. |
5th Sep 2018 8:39am |
