Home > Technical (L322) > [SOLVED] Testing Battery Drain Instructions Help |
Kiamaria Member Since: 23 Jan 2018 Location: Cheshire Posts: 23 |
My battery drain didn't show up anywhere until i pulled the connector on the neg lead module. |
27th Jun 2018 6:43pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
@Kiamaria
27th Jun 2018 9:40pm |
Definitely on Fuse 49, amperage dropped to 0.05 amps when pulled and car asleep.
30th Jun 2018 5:04pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
Does you car have a Connect 2 box about the size of a packet of cigarettes in the wiring harness running below the TV module. It's part of the original car phone system. If so you could try removing it. Undo the two plugs connected to it and plug the plugs together. They are m/f and blue if my memory serves me correctly.
30th Jun 2018 7:10pm |
A good shout, but I have already removed it sometime ago and plugged the two connectors together
30th Jun 2018 10:01pm |
More testing:
1st Jul 2018 12:35pm |
Try unplugging the aerial to the sat nav only. Leave the Satnav connected. |
1st Jul 2018 1:00pm |
Decided to dismantle the satnav unit, which was/is working, to see if anything obvious inside.....
1st Jul 2018 2:26pm |
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 |
1st Jul 2018 4:49pm |
I wonder how many Satnav units have been scrapped when all they needed was their teeth cleaned.
1st Jul 2018 5:20pm |
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3519 |
Great news Joe, well done!
1st Jul 2018 6:27pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
Good find Joe. What is that mess? 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
1st Jul 2018 8:40pm |
I guess it is just corrosion from some previous water ingress, am guessing that this was causing a short of some kind, or quite simply, as often is the case , the very act of dismantling and putting back together resolved the issue .
1st Jul 2018 10:09pm |
kgeddes Member Since: 11 Jan 2015 Location: UK Posts: 289 |
I’ve just had fuse 49 diagnosed for my battery drain issue. Still to confirm what component is the cause. Fuse 49 removed at the moment. Wish I’d seen this thread earlier! |
23rd Apr 2021 9:59am |
