Home > In Car Electronics (L322) > navcoder help required please |
dirtymonkey38 Member Since: 14 May 2017 Location: West Yorkshire Posts: 158 |
Is it USB to serial adapter? Could be the driver on the pc your using or maybe an incompatible chipset in the USB adapter? 2011 RR Autobiography 4.4 TDV8 |
1st Jul 2018 7:42pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7631 |
I had a few issues with USB...you have to use the same socket you used when you set it up. My issues were PC related...not the car.... worth a check. 2011 Range Rover Vogue SE 4.4 TDV8
1st Jul 2018 8:08pm |
Shambler Member Since: 04 Nov 2017 Location: Gloucestershire Posts: 41 |
I’m using a usb to obd port adapter that I got from flea bay, it came with a disc but can’t seem to get the disc to load so maybe that is the problem, any idea where I might down load drivers from? |
1st Jul 2018 8:21pm |
Try windows update. Any chipset info on the item you won? You could try searching for them on google if you have that info 2011 RR Autobiography 4.4 TDV8 |
1st Jul 2018 9:24pm |
To be honest I’m not a computer wizard and wouldn’t know about chipsets etc lol, laptop is only about a year old and up to date I believe 🤓 |
1st Jul 2018 10:01pm |
I meant the chip in the serial adapter. Have you got a link to the one you bought? I’ll have a look for you 2011 RR Autobiography 4.4 TDV8 |
1st Jul 2018 10:22pm |
I’ll try and find it, I bought it a month or so ago and don’t think the same are on Ebay anymore though there are a couple similar, give me a moment and I’ll see what I can find 👍🏻 |
1st Jul 2018 10:29pm |
1st Jul 2018 10:36pm |
1st Jul 2018 10:41pm |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1516 |
I've had no problems but I'm using the Resler interface.
2nd Jul 2018 12:19am |
looks like that plugs into the OBDII socket. I had the Resler unit that connected to a USB serial adapter that then plugged into a cable you disconnected from the nav unit. Serial adapter chipset was finicky and had to be FDTI compatible. With yours plugging into the ODBII port I'm not sure....its either the drivers on the PC or com port needs setting.right click my computer\
2nd Jul 2018 8:28am |
by the way, what is it you are trying to do with navcoder? 2011 RR Autobiography 4.4 TDV8 |
I think the cable you buy has to be compatible with navcoder....that one looks like it comes with its own diagnostic tool.....might be wrong....
2nd Jul 2018 6:18pm |
Just trying to set a few bits n bobs, tv etc and supposedly I can use it for setting up Bluetooth for the phone etc when I’ve fitted it? |
2nd Jul 2018 8:28pm |
