Home > Wheels & Tyres > 295 40 22 anyone fitted them yet? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16170 |
A quick pic pre prep
8th Jul 2018 10:34pm |
Stephen.Gazard Member Since: 10 Apr 2012 Location: Bristol Posts: 181 |
Looks good .. Guessing it wonβt look quite the same shortly π
8th Jul 2018 10:48pm |
MPx Member Since: 29 Jul 2011 Location: South Somerset Posts: 525 |
You see again this is just not true. I've put a 2.25 piper exhaust with sports cat on my Elan (instead of the std 2inch). I also removed the PreCat and had some work done on the ECU to take advantage of the new freer flow and picked up more than 20% power gain - very clearly seen/felt on track. I agree that putting a dustbin exhaust on a 1.0 Vauxhall Corsa is pure ASBO and nothing to do with performance but bigger freer flowing exhausts are definitely part of a path to greater performance. ....and I put some special stripes on my RS Turbo in 1987 which I'm sure made that quicker too Mike - MPx 2017 5.0 V8 Supercharged SVAutobigraphy Dynamic SVO Palette Grey (2021-...) 2012 5.0 V8 Supercharged Autoboigraphy Orkney Grey (2017-2021) 2007 4.2 V8 Supercharged Vogue SE Tonga Green (2012-2017) 2002 4.4 V8 Vogue Bonnatti Grey (2008-2012) |
8th Jul 2018 11:15pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
You finally took the plunge then Craig! Hope you managed to get a good deal.
9th Jul 2018 7:47am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34915 |
I'm looking forward to seeing what it looks like after you do your 'magic' to it.... ... - .- -.
9th Jul 2018 8:07am |
Thank you gents... am currently on a train inbound to collect her π¬
9th Jul 2018 11:15am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7758 |
I did mean the pipe after the backbox..... However, I'm sure the sports cat, removal of the PreCat and the work on the ECU all made more difference than the 1/4" - not to mention the new pipe probably had smoother bends |
9th Jul 2018 12:33pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
LOL, don't get too excited, the only srious troubles I had upon buying RRS were with dealers: one Toyota for a 3.6L 322 (the alternator failed on the way home from the dealer!) and a Porsche indy for a 4.4 TDV8 322) all private purchases was all good on the long run. Anyhow, enjoy your new ride! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l Current RANGE ROVER Vogue 4.4L SDV8 - 2013 - Indus Silver, on Almond. RANGE ROVER Vogue 4.4L V8 - 2002 - ex-2003 G4 Challenge Event Vehicle, Stage 3: Australia RANGE ROVER HSE 4.4L V8 - 2004 - one-of-one Overfinch RANGE ROVER P38a 4.0L V8 - 1999 - ex-2000 TReK Event Vehicle: South Africa Previous: RANGE ROVER Vogue 4.4L TDV8 - 2012 - RANGE ROVER 3.6L TDV8 x3 - RANGE ROVER Td6 x1 - RANGE ROVER Classic 3.5L V8 x1 |
9th Jul 2018 1:21pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Good luck with the new car sir 2015 4.4 AB
9th Jul 2018 4:22pm |
