Home > Maintenance & Mods (L322) > PCV replacement
bruno22rf
England 2004 Range Rover Vogue 4.4 V8 Java Black
PCV replacement
Going to get mine replaced (04 4.4 petrol) and was wondering if I should buy anything other than the valve itself - recall hearing that the connecting pipework often needs renewing as well? Anybody know which pipes and where is best to buy them?
Post #482999 9th Jul 2018 5:39pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
Yep there are 4 pipes you will probably need
Thin Breather Hose LR003814
Main Breather Hose 8510366
Main Breather Hose 8510367
Stubby Hose LLH000110
You may also want to do the Cyclone as well but they can be flushed out instead - Breather Seperator LLP000010
Dan @ Duckworths best port of call, or anyone parts place like Island 4x4
There is a good write up on here if you search on how to change them and all the parts. Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #483001 9th Jul 2018 6:00pm
bruno22rf
Many thanks nicksaab - most helpful - managed to get all but one hose in blue Silicone for under £30 the lot.
Post #483156 11th Jul 2018 12:36am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
Just a little caution -- my hoses needed to be replaced so thought I'd do the valve as well -- so I set off to my trusty mechanic with all parts in hand -- he's been mechanicing for 40 years, and I have 100% faith in his ability!
Long story short we couldn't get the Torx bolts out of the PCV, despite having a complete workshop of tools at our disposal -- so just changed to hoses.
We have knackered two bolts -- so probably an angle grinder at some point Sad
Happy bolt hunting Very Happy
Post #483175 11th Jul 2018 11:52am
holidaychicken
If you can get them out then swap them for hex head, I changed mine when I did the valley pan and guides.
Angled head windy drill if the torx heads strip or take out the inlet manifold as the little pipe that runs under it will break off the valve anyway
Post #483245 12th Jul 2018 12:41am
p38arover
Australia 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
I can't find the PCV in MicroCat. Would you know the part no.? Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #483251 12th Jul 2018 8:40am
Bushy30
Thanks for the tip -- a job for another day..............
LKR000040 is the part number I have, and oddly I have a new one spare Wink
Post #483264 12th Jul 2018 10:57am
bruno22rf
Do the actual valves wear out then? - would I be safer just changing the pipes or would that be false economy - considering suggesting to my mechanic to try removing the Torx but if one strips then abort the job and just do the hoses.BTW - bushy30 if you want to sell your spare please let me know how much you would like for it.
Post #483269 12th Jul 2018 12:01pm
p38arover
Thanks Bushy. I can see why I couldn't find it - the item's images in the emissions control parts page and the inlet manifold parts page are totally different.
Regrettably the postage from the UK to Oz would probably preclude my taking it off your hands. Sad Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #483270 12th Jul 2018 12:04pm
p38arover
Storey Wilson suggests they should be changed. See  Ron B. VK2OTC
2004 L322 V8 Auto
2007 Yamaha XJR1300
Post #483271 12th Jul 2018 12:05pm
Bushy30
Bruno, it's the rubber diaphragm that breaks down, so yes -- Storey does say that you can swap them if the unit you have can be opened -- my replacement couldn't be opened, so haven't tried the one on the car -- I ended up simply changing hoses and cyclone.
It's a job I'll get to one day -- currently have a thermostat failure, which caused and overheat Sad -- so I'll be keeping the spare for a while -- got all the bits I needed from Island4x4 Very Happy
Post #483273 12th Jul 2018 12:56pm
bruno22rf
Duckworths were asking £112 for the valve and £12 for the thin pipe - ebay trawling got both items, inc postage, for under £60 - running my car on a tight budget so every penny counts.
Post #483298 12th Jul 2018 5:48pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Have a go doing the thermostat mod / upgrade there’s plenty of info here on the forum.
Essentially it’s a lower temperature thermostat that opens earlier and prevents overheating, there are a lot on here that have carried out the mod and had absolutely no problems. It’s a relatively easy job and if yours is goosed anyway..........
Thumbs Up ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #483302 12th Jul 2018 6:07pm
Bushy30
Thanks Simon, and good idea -- apart from the fact that I ordered the thermostat and had it delivered already Sad
Only then to read about the mod! I'll start another thread Wink
Post #483303 12th Jul 2018 6:18pm
UK Marine
That’s a shame the mod really does take the strain off the engine, I’m not exaggerating when I say that the first time I started the motor and took it for a run I really could tell the difference.
Send the new one back - go on you know you want too Very Happy ______________________________
Simon
Post #483305 12th Jul 2018 6:22pm
