Home > Maintenance & Mods (L322) > Fitting new rearview camera (non LR camera)
mercuryf1
Malaysia 2015 Range Rover SVAutobiography 5.0 SC V8 Loire Blue
Reverse cameras can be easily found in any car accessory shop. Prices range from 20 GBP to 200 GBP, depending on quality. I went for the most expensive one as not only was it HALF the price of an original LR reverse cam, it also has wide angle lenses, 2 year warranty & infra red vision. (for low light)
Installation took an hour as the shop had never worked on a FFRR before. From my observation, it was a relatively easy job. I wanted the new cam to be located in its original place under the rear top spoiler. Easier way would have been to stick the cam onto the number plate but then the car will look funny with 2 rear cams!!
I am happy with results. if I were to do it again, i would choose the cheaper camera option as the resolution on the in-car touch screen (06MY) is cr*p therefore not doing justice to a good quality camera!
Removing the brake light and rear spoiler to access faulty original camera.
removing the faulty camera from the rear top spoiler.
Camera box (made in Korea)
putting the new camera into the old plastic housing.
Melting some glue to stick the unit back onto the spoiler.
new camera attached to 'old' plastic housing
new camera ready to be fitted into old plastic housing.
putting the rear spoiler back.
this is image I see when in reverse gear. It works at last! '01 1.8i Freelander. Grey/ grey
'06 4.2 S/C Buckingham Blue/ Parchment
'15 5.0 S/C SVA Loire blue/ Black
Post #48397 1st Feb 2011 8:24pm
dan_uk_1984
Great info here, certainly worthy of a link in the [urlhttp://www.fullfatrr.com/wiki/]WiKi[/url] I think.
Dan
Post #48398 1st Feb 2011 8:29pm
mercuryf1
Thanks Dan! My small contribution is a mere fraction of all the help you have provided the forum!
Thumbs Up '01 1.8i Freelander. Grey/ grey
Post #48399 1st Feb 2011 8:35pm
thats a good write up.. Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #48410 1st Feb 2011 9:08pm
Stocky
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Fuji White
Good job Mercury Thumbs Up
What is the picture like at night with the IR? Is it worth doing just for that?
Post #48522 2nd Feb 2011 8:45pm
mercuryf1
Not necessary as when reverse is selected, the reverse lights are bright enough already. '01 1.8i Freelander. Grey/ grey
Post #48523 2nd Feb 2011 8:49pm
DeRanged Rover
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Hi Mercury,
Did the new Camera fit straight into the housing for the old one or did you have to do sme modification? What about the wiring and other connections - straight swop or some soldering etc required?
Any chance you can put up a link to the camera that you got?
Thanks! African Bush Junkie ... in London!
Stats:
2006 TD6 Vogue SE
1972-2015 DeRanged Rover
2001 P38 dHSE (SOLD)
Post #123413 24th May 2012 10:59am
mercuryf1
Although I didn't carry out the mod myself, I was watching the mechanic who fitted it. Some cutting of the original housing was required to get the new cam to fit. He very quickly attached the wires (no soldering) next. Looked simple anyway!
Don't have a link as I bought the camera from a shop locally I'm afraid. '01 1.8i Freelander. Grey/ grey
Post #123558 25th May 2012 4:22am
killatomato
United Kingdom 2005 Range Rover Vogue Td6 Java Black
What is the biggest size camera I can fit into the oem cam holder?
Post #133172 27th Jul 2012 12:36am
