Home > Technical (L322) > 2003 4.4 petrol struggles to fire when hot. |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 |
HiDavid have you had the plugs done ? Check for air leaks and possible oil leak on rocker cover gasket contaminating plugs and coils .Dirty injectors? Is she Lpg?. Good luck |
23rd Jul 2018 8:54am |
nicksaab Member Since: 28 May 2013 Location: Wimbledon and West Wales Posts: 559 |
sounds to me like ignition coils Current Fleet:-
23rd Jul 2018 9:02am |
Zambezi Member Since: 07 Feb 2015 Location: Bury St Edmunds, Suffolk Posts: 67 |
I replaced the plugs about a year ago, some 5,000 miles. There was oil in the plug holes so the cam cover gaskets do ideally need replacing.
23rd Jul 2018 9:07am |
I would definitely check coils nor doing any harm giving them a clean . Misfire will throw up all ki nds of probs especially when it is intermittent .Will also damage catts |
23rd Jul 2018 9:32am |
Thanks. Will do.
23rd Jul 2018 9:43am |
tb10 Member Since: 17 Feb 2015 Location: Bromsgrove Posts: 332 |
Hi David,
23rd Jul 2018 9:44am |
Bank 2 I believe is passenger side do you have lpg? |
23rd Jul 2018 9:45am |
Thanks Rik
23rd Jul 2018 9:52am |
Yes eml light can come on intermittent fault codes pointing to lean mixtures at lamda mine been doing it for years no prob just gas to clean .Gas service should fix any problems .How long since last service ?I changed out vaporizer and filters as well as injector cleaner this year suspected diaphragm leak not expensive .Gas injectors need a clean now and then .As with petrol ones . lpg can be problematic if not serviced reg . Quite difficult to get a lpg engineer who realy knows his nuts found a good one in Edinburgh bottom of Leith little back street garage but has all the kit and not expensive good luck |
23rd Jul 2018 10:13am |
Thanks Rik
23rd Jul 2018 10:22am |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
If you're getting consistant lean codes when on lpg you do have an issue and risk valve damage
23rd Jul 2018 10:24am |
60000 miles eml on and off still running like a watch BMW engine pretty bullet proof towed caravan for 100s of miles with light on no problem jag engine a bit softer in the valve seats |
23rd Jul 2018 10:50am |
Check also for air lock in cooling system as vaporizer needs to be water heated to work and is first to suffer if air locked could be the reason why she switches to petrol |
23rd Jul 2018 11:06am |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 |
have a read here :
23rd Jul 2018 11:36am |
