Home > Technical (L322) > 8 speed gearbox oil flush recommendations and advice please
Page 2 of 4 <1234>
curious to know if it drives any better Stu.. ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #446212 30th Jul 2017 9:51pm
stu
Stan, I think it does! was getting a bit notchy especially at slower speeds and when you throttle off, bearing in mind these boxes are probably as near as good as it gets in an auto!
with the ecu being reset it learns your style from the off as well, so much smoother change now in my opinion.
As i said its all personal preference on some things and i chose to do it this way to get as much of the old oil out as was possible and replace it with fresh. It has got to be better! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #446225 31st Jul 2017 6:49am
that's good to hear Stu... Thumbs Up ... - .- -.
click link for ,
FORUM WIKI
HOW TO Ǝꓕ∀ꓕOꓤ PICS
Post #446226 31st Jul 2017 7:17am
sparkyxm
England 2011 Range Rover Autobiography TDV8 Bournville
Hi all,
I also have a 2011 4.4 TDV8.
I've had it a year, 8k miles done so far, only issue was a damper wire on the front strut (easy fix).
The vehicle has now done 58k.
I had a major LR Dealer service carried out when I bought it at 47k and was told no issues following a full faults analysis.
Recently its done a fair share of work towing trailers with vehicles on and I've not had any problems.
This week I had 5 people and all luggage on board, 150 miles into a trip (mainly motorway) it had the gearbox overheat message displayed.
It's now cleared, but made me think it's time for a GB oil change.
Is the earlier cooler blockage fault still a problem on this model year?
I have also noticed a slight 'wheel bearing' sound noise but can't detect where it's coming from, possibly the front.
Are there any issues with the CV joints or wheel bearings, or diffs?
Might this all be related in some way?
Andy Ratione non Vis
2011 L322 4.4 TDV8 Autobiog (Eroll)
1964 SIIA SWB Tilt (Smokey)
1968 SIIA 109 Safari (Bramble)
2011 Transit SWB (The Van!)
Post #481290 18th Jun 2018 3:47pm
GraemeS
For your possible wheel bearing noise, check that the pipes from the ABS modulator are all properly spaced apart by the spacers. I had a right front wheel bearing replaced to no avail trying to fix this noise only to discover an unattached pipe was vibrating on an adjacent pipe well down the void.
Post #481308 18th Jun 2018 9:53pm
dirtymonkey38
Whats the name of the place in Selby. I need to replace a sensor too which is housed in the sump 2011 RR Autobiography 4.4 TDV8
Post #484007 21st Jul 2018 8:34pm
bishbosh10
This is interesting - my 2011 was in for a megaflush and service but my indie (used for 20 years and totally trustworthy) called me up to ay you can't do a megaflush on the 8 speed box as there is a thermostat in the system that closes when the cold flush fluid hits it preventing the flush...?
So I just had the oil changed (84k) and the oil that came out was clean so probably wouldn't have benefitted from a megaflush anyway Smile Good news all round - £300 +VAT saved and a clean bill of health for the box! Bish.
2005 110 TD5 CSW
2011 TDV8 Vogue SE (gone)
Post #484010 21st Jul 2018 9:11pm
That seams far too cheap sir... The oil is £48 per litre from JLR let alone the cost of the filter!
Post #484023 21st Jul 2018 11:52pm
Mikey
The 8 speed CAN be flushed without issue Thumbs Up
Post #484027 22nd Jul 2018 6:56am
dirtymonkey38
the place in Selby? Whats it called? 2011 RR Autobiography 4.4 TDV8
Post #484235 24th Jul 2018 5:16pm
Baltic Blue
Quattro
They didn’t change the filter in mine just a flush change, but I regret not getting it done.
Post #484238 24th Jul 2018 5:39pm
dirtymonkey38
As always, thanks Mike 2011 RR Autobiography 4.4 TDV8
Post #484239 24th Jul 2018 5:40pm
GGDR
saw this posted by Grofus:
Quote:
Engine oil & filter changed. Transmission flushed by pumping out dark grey fluid out of the cooler line. Fresh oil in the old fashioned way. Very time consuming and awkward.
Wondering if this technique is possible on the 8-speed ?
Planning to change the fluid but I want to change more than the 4 that'll come out by gravity. Total capacity is 8.5litres.
. Cheers, Greg
Post #491628 9th Oct 2018 8:30pm
Mikey
No Thumbs Up
Transmission cooler is not very accessible
Thermostat in the pipes stops you fitting any oil back in
The only way to flush, is using a dedicated flushing machine
Post #491666 10th Oct 2018 8:02am
GGDR
Ok thanks a lot Mikey
. Cheers, Greg
Post #491669 10th Oct 2018 8:39am
Page 2 of 4 <1234>
