Home > Technical (L322) > Rev counter |
ptaroni Member Since: 20 Dec 2015 Location: leicestershire Posts: 89 |
Does it jump up like 200 odd rpm at a time? Like steps almost but doesnt actually feel like it |
9th Aug 2018 9:55pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Yes it seems to don't know wether it's my foot or the car |
11th Aug 2018 4:52pm |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1692 |
Fluctuating a few hundred rpm’s when under load? |
11th Aug 2018 5:17pm |
No mate just when going steady at about 1500 rpm |
11th Aug 2018 5:28pm |
Did a gearbox oil and filter change this morning at work, used some mpm m1375.4 oil , drained and filled then ran with that twice then filled with ravenol 6hp ran then drained then filled again, reset adaptions and now my issues have completely gone!
11th Aug 2018 6:52pm |
Mmmm food for thought it's just had a gearbox oil and filter change , maybe worth doing it again a few £££s now is better than £1000s later |
11th Aug 2018 7:27pm |
What oil did they use? |
11th Aug 2018 7:42pm |
Not sure it's in the sevice book as oil and filter change and the filter is new
11th Aug 2018 8:28pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
For TDV8 http://www.fullfatrr.com/forum/topic47773.html . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
11th Aug 2018 8:44pm |
So it's 71141 and a plastic or metal filter ? |
11th Aug 2018 9:10pm |
For the filter, a Landrover one will be plastic, there are others with a metal pan and separate filter, designed to overcome subframe obstruction on Spurts and Discos.
12th Aug 2018 12:57am |
ZF lifeguard 6 fluid is the way to go, though merle and get an oem filter from filtrans which is plastic. Don't try to use any other spec of fluid as it will not be happy.
12th Aug 2018 2:51pm |
Will do
12th Aug 2018 5:04pm |
I ve been watching this rev fluctuations and they only happen when the gearbox is cold once up to temperature everything is as normal so will leave the oil change until the summer |
4th Nov 2018 1:58pm |
