Home > Wheels & Tyres > Range Rover sport 19 inch wheels on Td6 can you do it? |
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 775 |
I have had 19" rims on mine from both L320 and L494. You only need the correct wheel nuts. I just buy set of wheels with good tyres then move them on when worn down but still legal. Keeps the cost of tyres to zero. The best combination for ride comfort, off-road use and cost is 265 60 18 but they don't look as good as 19`s or 20`s 2007 TDV8 VSE
29th Jul 2018 2:27pm |
SidewaysMatt Member Since: 25 Feb 2016 Location: Ledsham, Cheshire Posts: 173 |
I think the issue you're referring to is that the TD6 was only ever available from new with 18" or 19" wheels, not 20".
13th Aug 2018 4:03pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7635 |
TD6 only available with 18’s when new.
13th Aug 2018 4:46pm |
13th Aug 2018 4:51pm |
Ah I stand corrected Thought they were also supplied with 19" 2004 Vogue TD6 - Remapped
13th Aug 2018 5:11pm |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3062 |
I had these sport 19” on my 2002 TD6 and they were brill handling wise.
13th Aug 2018 11:02pm |
bishbosh10 Member Since: 25 Apr 2013 Location: North Somerset Posts: 344 |
Just make sure whichever wheels you fit are load rated for your L322. Bish.
21st Aug 2018 12:57pm |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
It's just the xl (extra load) rating you need but most 4x4 tyres have this anyway |
21st Aug 2018 4:53pm |
matlandy Member Since: 06 Aug 2016 Location: Crawley Posts: 134 |
This is mine with 19" RRS wheels on and GOODYEAR WRANGLER DURATRAC tyres fitted just had to change the wheel nuts.
21st Aug 2018 9:41pm |
horsedentist Member Since: 23 Jun 2017 Location: london Posts: 158 |
Cheers for all the comments guys. All on and they came with brand new perelli Zero tyres they seem to perform very well tyres could have done with being 55's rather than 50's throws the speedo out a bit but it was not accurate with the 18's on so now about 4mph adrift I can live with that until these tyres are worn out. |
3rd Sep 2018 11:35pm |
