Home > Technical (L322) > Help!!!!!! |
MattC Member Since: 27 Oct 2016 Location: Surrey Posts: 25 |
Check the top right rubber hose from the intake manifold. Take off the plastic engine cover and it the further towards the windscreen on the right hand side- they have a tendency to split. You should be able to either feel the split, or feel oil leaking out.
13th Jun 2018 9:23am |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3676 |
13th Jun 2018 9:42am |
VIRGIN Member Since: 04 Apr 2018 Location: SOUTH WALES Posts: 10 |
Thank you for your replies, its been a great help |
13th Jun 2018 12:42pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1619 |
welcome to the forum - stick around 405 AB exec seats Baltic and Cirrus
13th Jun 2018 4:51pm |
Thank you |
14th Jun 2018 7:47am |
Well over 50 4.4tdV8 owners on here to help you by sharing experiences and knowledge.
14th Jun 2018 7:57am |
Thank you Mike, I'll post the solution as soon as I find it
14th Jun 2018 8:50am |
The original 4 hoses are very soft pliable rubber, but the replacements are much tougher.
14th Jun 2018 9:42am |
the EGR open circuit is a ghost fault too. It crops up on several cars on here and there is pretty much a "they all do that" from time to time attitude from LR. I would doubt it is the cause of your fault. Much more likely to be boost related. While you have the engine cover off check and clean the MAP sensor on the intake plenum. Its the sensor with the red arrow pointing towards it on the pic above. It can get gunked up and give false readings of the pressure in the manifold. which can cause issues too. Bit of contact cleaner should clean it up. just take out the torx screw and the sensor pulls out.
14th Jun 2018 5:16pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4228 |
Where does one purchase said replacement hoses from chaps? 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
28th Aug 2018 5:54pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34920 |
ask dan at duckworths in his section. |
28th Aug 2018 6:01pm |
Dan’s the man
28th Aug 2018 6:04pm |
Great! Learning lots. Appreciate all the help and advice on here 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
http://www.fullfatrr.com/gallery/albums/us...G_1518.JPG
28th Aug 2018 6:17pm |
