Home > Duckworth Parts > Fuel Pump Electrical Connector Repair Kit
SteMY06HSE
Qatar 2006 Range Rover HSE 4.4 V8 Zambezi Silver
Hi Dan,
After a botched repair job from a local independent after a fuel pump failure I have had the problem re-occur. After a further inspection it looks like they have messed up the wiring harness and cables as the fuel pump looks new.
A quick look in the Electrical Library from Topix reveals its connector C0115 and carries a part number of YPC906770 with a repair kit for terminals 1-2, 5-6 with part number YPE100740 (not sure if the VUB900990 part number is relevant to anything)
Is it possible to order the connector and a wiring harness repair kit. As you can see from the photo, terminals 3 and 4 are also damaged, 4 I believe to be the main power cable with the insulation split and very loose in the connector block. There is no cross sectional area (CSA) for the cables in terminals 3 and 4 only listed as MAZA whatever that means.
I doubt if they replaced the fuel pump relay either when they fitted the new pump so a price on one of those as well would be great.
Hope you can help with some suggestions on the right kit to repair this,
Ste
Post #487600 30th Aug 2018 11:23pm
duckworthparts
Site Sponsor
Hi Ste
the connector YPC906770 I can get £4.00 -
terminals YPL901440 are the only good number on there, they supersede to 418233 which come in a pack of 10 £27.90 You can paypal direct using - www.paypal.me/duckworthparts
Please supply your full name address when sending a paypal payment.
https://www.facebook.com/duckworthparts
www.duckworthparts.co.uk
My Direct Line: 01673 849873
Email: robin.hall@duckworth.co.uk
Supplier of Genuine Land Rover & Jaguar Parts For All Models
Post #487614 31st Aug 2018 9:58am
SteMY06HSE
Thanks Dan,
Thats pretty much what I had come up with also... the smaller leads with CSA of 0.5 (x3) and 0.35 (x1) seem to go by the same number YMI900970 which when I search the inter-web for I can't find anything.
Is there any way to search the main Land Rover Parts Catalogue for Pre Terminated Leads of 0.5 CSA?
There appear to be loads on the LRCAT website but no details of sizes... just that they are 'pre-terminated leads' and a reference to Topix.
Hope that helps narrow the search down.
Post #487679 31st Aug 2018 10:18pm
SteMY06HSE
Hi Dan,
I have had a closer inspection of the damaged plug and it appears that the damage is limited to the two centre fat wires which you have provided the part number for. So assuming I can get the smaller wires out of the clip without damaging them then that will all be good.
I have a few other items I would like prices on to add to my order as my brother is coming out soon so I might as well load him up...
SALLMAM546A208212 if you need the VIN. Hopefully my part number guessing is holding up.
everything x1 apart from as noted. A quick look on the inter-web show the HO2 sensors as being quite pricey so if there is also an OEM alternative can you list that option too please.
a. MHK501140 H02 SENSOR - FRONT (I believe I need 2 - one for each side)
b. MHK500870 H02 SENSOR - REAR (x2 as above)
c. LR030048 REAR LINK - STABILISER BAR (x2)
d. LR055454 BRAKE PADS - REAR
e. SOE500030 SENSOR ASSY - REAR (x2) I broke one and want a spare.
f. LR019618 BRAKE PADS - FRONT
g. SEM000012 SENSOR ASSY - FRONT
h. 4526546 SEAL (MAP SENSOR COVER @ BACK OF INTAKE MANIFOLD)
i. LWF500020 SEAL (INDUCTION ELBOW @ FRONT OF INTAKE MANIFOLD)
j. YPC906770 ELECTERICAL PLUG - £4 (from previous post)
k. 418233 PRE-TERMINATED LEADS - £27.90 (from previous post)
Thanks in advance.
Ste
Post #488078 5th Sep 2018 3:08pm
