Home > Maintenance & Mods (L322) > L322 3-Button Key |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6399 |
If the key with the round end then yes you will have to get the blade cut, then swap over the internals.
6th Sep 2018 8:21pm |
bruno22rf Member Since: 08 Mar 2018 Location: milton keynes Posts: 69 |
Been down this road - I had Timpsons cut the new blade, about a tenner for 2 from memory, then just swapped the internals over - you might as well replace the batteries while you are in there and be careful not to drop the tiny piece of triangular plastic that sits inside - took me hours to realise that it releases the steering lock, in fact I threw mine away initially thinking it was a piece of packing . |
7th Sep 2018 7:47am |
Waynetab Member Since: 19 Jul 2015 Location: Rochdale, Lancashire Posts: 132 |
I bought this one
7th Sep 2018 8:10am |
Paul thornton Member Since: 23 Sep 2017 Location: Lancashire Posts: 545 |
Has anyone found an aftermarket 3 button key / fob which actually works?
7th Sep 2018 11:03am |
Gyre8 Member Since: 14 May 2017 Location: Wolverhampton Posts: 252 |
I bought a couple of these:
7th Sep 2018 4:17pm |
The ones that I bought had little rubber "posts" sticking out from the underneath of each button - these actuate the switch contacts on the board - I had to trim a couple of them down as they were constantly pressing on the switch contacts - I used the old fashioned safety razor blade snapped in half to make a neat job. |
8th Sep 2018 8:58am |
lounge_on_wheels Member Since: 10 Dec 2016 Location: in the great land of oz Posts: 269 |
I bought this one, took the chip from my old fob and slid it into the provided slot on this new flip fob, got key cut did the key synch and all works including the tail gate button.
9th Sep 2018 12:38am |
