Home > Maintenance & Mods (L322) > oil overfill
aggraa
oil overfill
Hi, I purchased my 2010 4.4 tdv8 in April , and drove it to Bulgaria and back ,so a total of about 5000 miles since I got the car.
Today while I was waiting in a car park for a mate I checked the oil level on the dashboard and it says my car is overfilled.
Can anyone give me an idea of any problems I can expect from this happening...I havent added any oil since I purchased it.
And to add to my paranoia ,when I pulled out of the car park my tyre pressure warning came on ...so it was a slow drive home.I inspected the tyre and a nail has gone in ...easy fix, its the engine oil level thats concerning me.
Post #488514 9th Sep 2018 6:54pm
GGDR
Take another reading tomorrow aggraa. Try a cold reading too. The bonnet needs to be open, there is a sequence of keys you press to get a reading when the engine's cold. Also be patient when reading. Mine comes up a notch or two from the initial reading after a minute or two.
I read one case of a faulty sender a while back.
Bring back dipsticks!
. Cheers, Greg
Post #488520 9th Sep 2018 7:32pm
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
I had to buy a new dispstick as mine was no longer reaching the oil.......
Post #488560 10th Sep 2018 10:30am
nino_nino
aggraa,
in the morning with cold engine oil level should be in the middle or max. one notch above. Thumbs Up Thumbs Up 2012 TDV8 Black Edition
2000 Disco. TD5
1975 series III
Post #488561 10th Sep 2018 10:37am
CS
My experience was that the gauge was very sensitive to the car being on perfectly level ground, and as it reads in whole units rather than being infinitely variable, as a dipstick would be, the effect can be exaggerated. The handbook talks about testing while warm, but my dealer recommended testing cold and in the same place every time, and when I did that the apparent overfill turned out to be an illusion.
But keep monitoring the level as a rising oil level when you have not added any oil can indicate other problems. Only Range Rovers since 1988
Post #488571 10th Sep 2018 11:41am
aggraa
Hi thanks for the replies. I havent been to my car today as i have been on the phone all day so far, thought i would check this thread on my coffee break.
In the morning I have a 80 mile round trip, so I will check the oil level before I leave and when I arrive 30 miles and an hour later when everything is hot.
Thanks again ,I will sleep better tonight.
Post #488589 10th Sep 2018 2:45pm
will be more when hot.
The correct procedure is to check when warm, do you trip, then turn off car and let oil settle for 15 mins then check. There is nothing that can't be fixed with a hammer😜😜
Post #488595 10th Sep 2018 4:06pm
aggraa
Hi, hopefully I have attached 2 pics..first one is before I started my car this morning..2nd is 10 mins after my drive..
Post #488658 11th Sep 2018 11:30am
aggraa
If the pics didn't show..I can't see them on my phone...all is good Smile
Post #488659 11th Sep 2018 11:33am
Hairy Dan
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Thumbs Up Cheers Ian
Kielder 4x4 Safari
Post #488660 11th Sep 2018 11:47am
aggraa
thanks for doing the pics,
I got my tyre fixed £15 , I recommend KMC tyres in Norwich, I have used them for years, puncture repair, fitting new tyres supplied by me and buying tyres from them . Usually there is a bit of a wait 30mins or so but its worth it, Wheels removed with a breaker bar , care taken to jack in the correct place, replaced with a torque wrench and all tyre pressures checked even if only one tyre has been worked on.
It was a nice drive home tonight with no warning lights on the dash and not worrying about the oil, I must remember to put my headlights back to UK driving tomorrow
Aaron
Post #488710 11th Sep 2018 8:45pm
