Home > Technical (L322) > A group of sudden error messages. HDC, transmission, etc. |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6665 |
Nick, check your battery level. A lot of unexpected (and unrelated) fault messages are cause by a potentially duff battery. Got - 2017 SDV8 Autobiography in Loire Blue
19th Sep 2018 10:26am |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7764 |
Agree it's most likely battery related - if the current one is >5 years old, then buy a new one - if newer, may be worth getting it tested.
19th Sep 2018 11:01am |
Nick591 Member Since: 04 May 2017 Location: Charfield Posts: 193 |
Thanks to both. Current battery is about a year old and the old one altbough not good did not lead to such messages. However I will try putting jump leads on and see if it makes any difference and report back. I had thought of diconnecting the battery and cleaning the terminals so will do that as well
19th Sep 2018 11:19am |
My cars the same vintage as you Nick and I’m on my 3rd battery in the time I’ve had the car, about 6 1/2 years or so. Got - 2017 SDV8 Autobiography in Loire Blue
19th Sep 2018 11:27am |
stu1 Member Since: 06 Dec 2013 Location: UK Posts: 276 |
I'm going to sound like Mr bleedin' obvious here, for which I apologise, but I would advise getting some diagnostics/codes read and anlysed before laying out cash. If the results point to low voltage, then investigate the charging and battery.
19th Sep 2018 12:03pm |
Stu, the issue with a potentially rogue battery, is that the fault codes won’t refer directly to a low voltage issue, however past experience has shown that getting several (unrelated) errors at the same time usually point that way.
19th Sep 2018 12:53pm |
Thanks for the further advice chaps. I have tried this evening to disconnect the battery negative for a minimum of 2 minutes then reconnect - no improvement. I also tried jump leads to a known good big battery - no improvement.
19th Sep 2018 7:22pm |
forrey Member Since: 24 Jan 2016 Location: alberta Posts: 24 |
hi ya .. try having your electric diff motor looked at ? mine broke and came up with the same faults ...hope it might eliminate your problem |
19th Sep 2018 9:25pm |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1271 |
My ediff motor is goosed at the moment , none of those faults appear apart from traction control message fault , IMO wheel speed sensor is the culprit , needs code reading but all those faults can be attributed to one gone u/s |
19th Sep 2018 9:46pm |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 |
I had the same symptoms earlier this year.
20th Sep 2018 1:21am |
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 785 |
Does it start alright when you turn the key. I had exactly this fault and it turned out to be worn contacts in the ignition barrel ! Seems that they where failing to send power to the various ecu's involved when you start up. |
20th Sep 2018 10:09am |
Thanks for further replies. Yes it starts OK. It is now with the Bosch garage over the road getting the codes read. We will see what they reveal.
21st Sep 2018 9:10am |
'Turning the ignition off and on always allows you to continue without any loss of function. '... do the faults go away as in you dont have limited gears, tc fault or handbrake fault ? I'm still going with ignition switch, a known fault on our model. |
21st Sep 2018 9:28am |
No, the comment about cycling the ignition only referred to the problem with the 'Engine System Fault'
21st Sep 2018 6:25pm |
