Home > Technical (L322) > Timed climate control |
it may be too warm at the moment for it to turn on, it wont bother igniting if the temp is above a certain figure, which I can't remember off the top.
23rd Sep 2018 11:41am |
AJGalaxy2012 Member Since: 11 Jun 2018 Location: Gainsborough Posts: 1463 |
Mine is doing this too, its the battery in my case. The battery starts the car just fine but is apparently too low a voltage to run the heater. I have proved it by leaving a C-Tek charger on overnight and the heater starts up and runs fine. BMW i3 Electric Car
23rd Sep 2018 12:24pm |
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 |
Thanks guys,I've tested my battery this evening as the car hasn't moved today so I should get an accurate resting voltage i think? The voltage is 11.8v engine off,which suggests it's fubared,though puzzlingly still starts the engine sharpish.I try charging the battery overnight then see IF the heater fires up correctly,incidentally is there such a thing as a nice easy way to charge the battery in situ by simply connecting a plug into the car towing socket wired from a 12v charger to put juice IN instead of crocodile clips onto the battery or would relays etc wired in prevent that method? 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
23rd Sep 2018 7:11pm |
If its a 13pin socket pin 9 is +ve pin 13 -ve, if you have the two 7 pin sockets, the grey one (12s) pin 4 +ve pin 3 -ve. BMW i3 Electric Car
23rd Sep 2018 8:05pm |
Great! That's really helpful,thanks! 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
23rd Sep 2018 8:19pm |
have a look in the forum shop.......
23rd Sep 2018 8:22pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7641 |
Just beat me to it....
23rd Sep 2018 8:23pm |
Or....
23rd Sep 2018 9:07pm |
Well I'm stumped over this climate heating! It seems to work only if the wind is blowing from the north and there is a Q in the month!!
2nd Oct 2018 11:07am |
