Home > Technical (L322) > Dropped suspension on my l322
petebowling
United Kingdom 2003 Range Rover Vogue SE Td6 Java Black
I have just been to get my l322 4 wheel alignment done, but they could not do it as when they measured the front distance from the bottom of the front wing to the middle of the wheel the left side was two centimetres different to the right.
There are no warning messages the air shocks work ok, I have replaced front wishbones joints etc I am wondering if I have missed something anyone any ideas? Rolling Eyes
Post #490577 1st Oct 2018 7:16pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Could it have been this way before your suspension work. If you have an IID tool you can reset the heights to the correct level. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #490585 1st Oct 2018 7:39pm
m@ttsFF
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
The joints should be tightened when the weight is on the wheels - could this be it? 4.4 AdBlu Tractor
4.2 SC - sold
Post #490587 1st Oct 2018 7:42pm
m@ttsFF
duplicate 4.4 AdBlu Tractor
4.2 SC - sold
Post #490588 1st Oct 2018 7:42pm
petebowling
I didn't do it that way weight was off, can it be jacked up without wheels on to put weight pushing upwards or do I need to have the wheels on?
Post #490589 1st Oct 2018 7:54pm
petebowling
The levels were ok before the work, I have a Hawkeyes can they be reset from this
Post #490591 1st Oct 2018 7:58pm
You will need to loosen off the front suspension nuts/bolts for the wishbones, get weight of car on the wheels at "normal height", then tighten up the bolts. Only then should you try calibration.
If you can get at them all (the nuts/bolts)you should be able to do with car on the ground, just have an axle stand in position in case the height drops. .
Post #490606 1st Oct 2018 10:04pm
Simply ask the garage doing the alignment if (maybe for a small fee) if you can put the car on the alignment ramp and loosen/re-tighten the wishbone bolts... That way you can do all the tightening with the wheels on the floor albeit on a ramp... Thumbs Up
Post #490613 1st Oct 2018 10:33pm
petebowling
What's a iiD tool? is that like a LR Hawkeye diagnostics tool
Post #492638 17th Oct 2018 9:34am
https://www.gap-diagnostic.com/products/iidtool/ .
Post #492642 17th Oct 2018 12:23pm
